I1000 questions
saxmann10
I1000 questions
Post by saxmann10 »
after a log is finished the play back only shows not supported also there is a prompt under dtc for obd2 -this button does not do anything i would think it would show live obd2 data.
does dslogredux work with i1000.
and when updating i1000 do you need to restore oem calibrations first
thank you again
Re: I1000 questions
you can not playback a log on the intune itself.. you'd need to save the data log to your Windows PC and use the DataViewer software to view the log...
DTC - OBD is for scanning/clearing trouble codes.. if there are no trouble codes thrown, it won't show anything..
dslogredux will work with inTune logs as long as you have a GM vehicle between 2000-2013...
2014+ newer trucks/vettes/etc, there is no fuel injector adjustment since they are direct injected, so no need to use dslogredux since you have no injector slope to adjust anyway...
and you can always get custom tuning done from www.diablewtune.com for even more gains/performance...
saxmann10
Re: I1000 questions
Post by saxmann10 »
thankyou that cleared alot up
