Update does not finnish
stimpy
Post by stimpy »
Hello,
I have been trying to update my recently purchased intune.
Sadly i am not able to complete the update process as it hangs on the last stage before restart.
If i restart manually then i don't have the new firmware installed.
My version installed on the device is 1r03t
The gm version is 1r01v
I only have the 87 oct tune available and really need the 93 oct tune.
Below a screen shot of the intune folder.
left the folder on the intune, right the folde on my pc with the update files i would like to install.
I have the intune married to my truck, could that be a problem?
O i just put the info file here also to give you as much information as possible.
I have a 2008 Silverado
my pc is win 8.1
Please help me update the intune.
info.xml
(2.71 KiB) Downloaded 348 times
Re: Update does not finnish
save this to the intune drive then let it load it, then run the auto updater and it will fix the issue :)
cdrom-1r01u.itf
(5.51 MiB) Downloaded 382 times
stimpy
Post by stimpy »
I have a cd drive E: Diablosport.
And a mobile disk called Intune F:
I cant write to the cd drive E:
I can put the file in Drive F:, but it does not do anything.
What am i doing wrong.
it goes on intune drive.
stimpy
Post by stimpy »
it is there right now but it does not do anything.
the folders on drive f:
.fseventsd
.Trashes
logs
tunes
the following files are these now.
._.Trashes
._InTune-1r03p.itf
sdrom-1r01u.itf
Group_Update.itg
info.xml
should i remove something first?
I don't wan't to risk loosing my original tune.
Also when the intune is connected to my pc for a while, suddenly it reads preparing and the circular thingie keeps running untul i disconnect it.
stimpy
Post by stimpy »
What should i do now.
I can try different stuff but i don't want to brick the device.
Please, I need some help.
preparing means its updating, let it finish...
stimpy
Post by stimpy »
But how long can it take?
I have waited for more than 1 hour.
I have never seen it take an hour, but if it says preparing/wriiting, etc, just let it go until it goes back to the main menu.
stimpy
Post by stimpy »
Yes, it finally worked.
It took me 1 hour and 15 minutes to complete.
i am on 1r04e now.
