Latest Intune release here.
Re: Latest Intune release here.
save this to the intune drive and let it import the fiile then load it to the vehicle then you may tune it.
- 68105857ac.drg
- (800.15 KiB) Downloaded 899 times
Hey guys. I just tried plugging the Intune into my 2005 C6 Corvette. When i run the program and try to write vehicle i get the message "PCM calibration for (vin#) might need an update. Attempt a backup read?" When I do the backup read, it tells me to email the file to support@diablosport which I did. I will try to post that in here and my info folder but I am not too great at this stuff. Please let me know if you can help me with getting this tuner to work!! Been happy with all my diablo products in the past, really want to be able to get this one to work! Thanks
- info.xml
- (2.21 KiB) Downloaded 690 times
Also here is the file it told me to email to the support email.
Dustin
Dustin
- PCM__UnknownBackup.grg
- (439.33 KiB) Downloaded 701 times
Just received a intune and looking for the latest update for a 05 M
agnum RT. Thanks in advance
load this update.dut192 wrote:Also here is the file it told me to email to the support email.
Dustin
- GM_TUNES-1t02mb.ITF
- (7.31 MiB) Downloaded 906 times
Ok Mike I will try that one my lunch break. Someone through the support email told me my software in the computer probably needs to be reset by the dealership, so they told me the soonest they can take it is thursday and its like 200 bucks. Hopefully that fixes it if this doesn't, I will surely let you know!mikel wrote:load this update.dut192 wrote:Also here is the file it told me to email to the support email.
Dustin
Thanks buddy
Tell us what's wrong
2015 mustang gt 5.0 gasolin
i used intuneAn error message will pop up when you connect a Intune
Please ask for help to Tech Support
Complete Auto Update
Do you connect with the car and told updates[/img]
I used Windows laptops
please post the info.xml file from the intune drive.
I now have the I-1000 DCX for my 2014 Challenger R/T after wasting a lot of time and money trying to use an I-1000. After updating the software by running inTune.exe, I connected it to my Challenger, and was notified that the device needed updating, which is what I had just done. What I've done so far, and the problems I'm having are posted here: http://www.diablosport.com/forum/viewto ... 33#p283133
I assume that updating it on a Mac requires dragging and dropping files, but exactly where do I put the files, and which files do I need? My inTune appeared to have the proper files in it when I verified which files were installed. So, when I connect it to my Mac, two USB drives appear (DiabloSport & INTUNE) on my Desktop, and there are folders in the drives. How do I know if my device is registered, and if it isn't, how do I register it? How do I update it on a Mac if that is what it needs? Also, I am going to have a custom tune written for me (I'm getting a ton of engine codes because of my mods), so once I have the tune, where do I install it?
Thnx!
Thnx!
- info.xml
- The info file for my I-1000 DCX
- (1.78 KiB) Downloaded 700 times
ksmith0110
I'm sooo confused.
I just wanted to update my Intune. It shows :
GM Tune Db: 1r01n
I thought I could just plug it in and update it, but there's so much information, I have no Idea what to do!?
The website wouldn't let me log in, but I looked back in my email history and it shows where I registered. I had to re-register. It said my email did not exist in the system.
I don't know what to do now.
GM Tune Db: 1r01n
ekallmotor
my intune keeps asking for pcm calibration update, 2010 challenger srt8
bhunter0830
After installing the boxed tunes and having a custom tune created. I go to install another tune and now i receive the "Vehicle is not supported, contact DiabloSport"
09 Challenger RT I-1000 inTune
I just received my InTune, the update progress is very vague for Mac. I updated the GM tune (which is what I have), but what else do I need to update? And how do I register?
- info.xml
- (1.07 KiB) Downloaded 678 times
alphamalert
Also can't do any updates on my intune. need to register it but can't seem to get that figured out.
info.xml below
info.xml below
- info.xml
- (435 Bytes) Downloaded 666 times
challengerguy
Hey guys tried plugging in the device to my challenger and it says PCM needs and update. What do I need to send in order in order for this to be fixed.
