A9L MAF voltage wont let me change
CMR Support
Re: A9L MAF voltage wont let me change
whats up with the idle rpm change in the functions in the file you posted?
How does the MAF curve look to you on this file?
I edited the bottom of the voltage function.
larrykerrtest_new.frg
(56.12 KiB) Downloaded 419 times
Mopac
Post by Mopac »
Mike, i didnt change anything in that tune... thats a box stock a9l tune with no changed parameters on my computer! ... i made that as a test file on my new computer to see if it would work with ANY a9l tune. On the file you sent to me, voltage from 1.89 v and lower has been highlighted red and is up a very small amount .. like 1%
yeah, I used the +/-buttons to make incremental changes, but I can edit it fine.
I am not sure what your issue may be.
Mopac
Post by Mopac »
i just tried the plus and minus buttons and it does the same thing...
and this is with cmr 5114?
deleted the ori and template?
check path settings for ori path to make sure its looking in right place?
Mopac
Post by Mopac »
Mike, i have tried deleting what i THINK is the correct ori and template file... can you tell me the exact name of the ori and template that it should be using? maybe its using the incorrect one somehow...
ori is gufbx9l.frg and tpl is gufbx.tpl
Mopac
Post by Mopac »
The ori file doesnt exist on my computer.... can you email me the ori file to [email protected]?
if you can open the file it must mbe there, or you already deleted it.
select a9l from drop down and click ok and it should download and open the file.
if its not going to your ori folder, then its the path settings as mentioned a while back....
Mopac
Post by Mopac »
when i delete those files, and try to re open the tune, i select download tune, it says "no matching file" .... this doesnt seem normal?
sounds to me exaclty like its downloading the file to the cal file folder, because your path settings are incorrect.
PLEASE, check that.
Mopac
Post by Mopac »
my template pathway is set to template, and the ori path is set to the ori folder, still does it...
I dont know.
This doesnt really add up, we're missing something.
Is the file in your ori folder now?
can you open it?
Return to “CMR Support”
