I can install the Diablotune and the truck runs great - however, 'adjustable parameters' and 'tune vehicle' seem to launch the same process on the tuner.
I don't get the ability to change the tire size, AFM off/on, throttle boost...none of that stuff. It just installs the canned tune and doesn't give me any options.
2015 GMC Sierra 6.2 - no options?
Re: 2015 GMC Sierra 6.2 - no options?
when you select the ECM tune to install, it will then ask you if you want to MODIFY the tune.. select YES/green checkmark to get into the adjustable parameters for the tune you selected...
inTune user manual: http://diablosport.com/manualFiles/inTu ... Manual.pdf
I know how it works - it worked right on my last truck. It just never does that. I'll have to take some pictures to 'prove' it
I am having the same exact issue as described here. Hoping there is an update so I can turn v4 mode off....same truck and everything.
Mike posted a file in another thread that I had made, check it out https://www.diablosport.com/forum/viewt ... 13#p284413bboyce536 wrote:I am having the same exact issue as described here. Hoping there is an update so I can turn v4 mode off....same truck and everything.
I was able to adjust tire size and disable AFM and the speed limiter etc, give it a shot
thanks Rob, yes, the attached update should resolve this.
- GM_TUNES-1t02ob.ITF
- (7.52 MiB) Downloaded 221 times
