Installing on 2015 SHO
imissnumber3
Post by imissnumber3 »
Okay people! I purchased a Trinity for my 2015 SHO. What an experience this was.
I will not tell you all of the issues and problems I had trying to save my original MAP file. First it takes about one hour to save your original PCM file to the Trinity. Try telling your SHO to stay alive for one hour. It will not happen. It keeps shutting off. There's nothing like getting through 45% of downloading the original program after 30 minutes and then having it fail.
After many attempts at trying to save my original PCM MAP to the Trinity I finally came upon a solution.
At the beginning, the Trinity tells you to turn the ignition on, left but do not start the vehicle. Bull! Here's what I did to succeed.
First I started my car.
Next, I told Trinity to install the Premium octane map.
I left the car running for about one hour while it downloaded the original PCM MAP to the Trinity .
When it was done uploading, it told me it was done uploading and had a button to continue.
I shut the engine off, then turned the ignition on by pressing the start button twice.
I then pushed the continue button on the Trinity.
It took about one minute to download the premium fuel performance MAP to my SHO.
I hope my experience helps other 2015 SHO owners who bought a Trinity.
Sure seems like early XP cloogy software to me.
sohfast94
Re: Installing on 2015 SHO
Post by sohfast94 »
There's a very clear message on the screen to "Read" or "Download" your stock file and if you choose to read the car then it tells you will take up to 60 minutes to do which will require a battery charger to do....
Insert Clever comment here...
elvisghetto
Post by elvisghetto »
Back in December I spent an hour getting the tuner to read my stock tune. This time I wanted to get around this so I went the other route and chose to download. This really is the easiest way to do it. After selecting download it will eventually come up with a screen telling you to connect it to you PC with a Continue button. Just unhook it from the car and go to the PC. Start the program DiabloSport Downloader and then plug in the tool with the mini USB cable. You will see "A Calibration Update" option this time and you want to do this. After that it will load onto your car much faster.
I went from a Dodge Charger to the Taurus SHO and I think that may have caused the problem.
I have the 2015 Taurus SHO with the luxury package and it is scary fast after the tune.
Return to “Trinity Ford Gas”
