Remove disabled rear O2 sensor to install wideband sensors
elad1591
Post by elad1591 »
I have a custom tune installed that has the rear O2 sensors disabled. Can I remove the rear o2 sensors and install wideband sensors for AFR/EGT?
Vehicle: 2014 Dodge Challenger R/T
Re: Remove disabled rear O2 sensor to install wideband senso
No, that will lead to codes for heaters, etc, nor is that the best place for a wideband, you want it as close to the collector as possible.
elad1591
Post by elad1591 »
mikel wrote:No, that will lead to codes for heaters, etc, nor is that the best place for a wideband, you want it as close to the collector as possible.
Thank you.
