Shift points under Quick Adjust
I have a 2007 5.7, running R20. What are the RPMs that each shift happens under the Raised Shift Points setting? Also, can the shift points be adjusted?
RE: Shift points under Quick Adjust
6100 rpm for the 5.7...no, it is not adjustable currently.
O.K do you mean the 1-2 shift or the 2-3, because mine only goes to 5800 before shifting between 1-2. I am just curious. I also have an 07 running r20 but I can't shift at 6100
I think its for the 2-3 shift, because mine shifts at 5800 for the 1-2 as well.
