Adjustable parameters
When I try to update the adjustable parameters it just skips it and goes directly to the tune. Is there something I need to do so I can get into these settings. I just want to change my tire size
2013 Ram 1500 5.7L
2013 Ram 1500 5.7L
Re: Adjustable parameters
tune vhehicle/write vehicle/select quick adjust.
that is what i try to do but it bypasses the adjustments and just goes to directly write the tune
I am having the same problem. I go to adjustable parameters and it goes straight into write tune mode with no option to adjust parameters. Working with 91 Octane tune.
we're looking into this, can you post the info.xml file from the intune drive please?
vision1234
I don't feel alone now...
Me toooooo
Me toooooo
Mike
Sorry for the delay in responding but I have been holidaying in Japan and have just returned.
Info.xml file attached as requested
I tried the Diablo Tune today to see whether that allowed me to fiddle with the adjustable parameters but I got the same outcome, i.e. going into Adjustable Parameters only offered me 1 option which was to install the PCM that I had already installed.
David
p.s. I have certainly noticed the impact of the Diablosport tune. Great throttle response and tighter gear changes. I just want to get rid of MDS now!
David
I'm having the same problem. I have 2 tunes from Sean at hemifever and I wanted to adjust the part throttle shifts. Anyway, when I get to the step where my inTune should ask about adjustable parameters it goes straight into writing the tune.
Is there a fix?
Is there a fix?
there will be a fix shortly.
Hey Mike any updates?
Still looking for an update so I can adjust my tune.
restore the stock tune then update the tool and then the params should be there.
