Adjustable parameters
mullenexd
Post by mullenexd »
When I try to update the adjustable parameters it just skips it and goes directly to the tune. Is there something I need to do so I can get into these settings. I just want to change my tire size
2013 Ram 1500 5.7L
Re: Adjustable parameters
tune vhehicle/write vehicle/select quick adjust.
mullenexd
Post by mullenexd »
that is what i try to do but it bypasses the adjustments and just goes to directly write the tune
dvanryn
Post by dvanryn »
I am having the same problem. I go to adjustable parameters and it goes straight into write tune mode with no option to adjust parameters. Working with 91 Octane tune.
we're looking into this, can you post the info.xml file from the intune drive please?
vision1234
Post by vision1234 »
I don't feel alone now...
Me toooooo
dvanryn
Post by dvanryn »
Mike
Sorry for the delay in responding but I have been holidaying in Japan and have just returned.
Info.xml file attached as requested
I tried the Diablo Tune today to see whether that allowed me to fiddle with the adjustable parameters but I got the same outcome, i.e. going into Adjustable Parameters only offered me 1 option which was to install the PCM that I had already installed.
David
p.s. I have certainly noticed the impact of the Diablosport tune. Great throttle response and tighter gear changes. I just want to get rid of MDS now!
gabrieldy
Post by gabrieldy »
I'm having the same problem. I have 2 tunes from Sean at hemifever and I wanted to adjust the part throttle shifts. Anyway, when I get to the step where my inTune should ask about adjustable parameters it goes straight into writing the tune.
Is there a fix?
there will be a fix shortly.
gabrieldy
Post by gabrieldy »
Hey Mike any updates?
gabrieldy
Post by gabrieldy »
Still looking for an update so I can adjust my tune.
restore the stock tune then update the tool and then the params should be there.
