U7130 Speed Limit Delete and Higher Rev Limit
Streetsmoker
Just wondering if you guys ever plan on adding this function??? Seems all the other Predator DL's for every other make has this except ours.
Streetsmoker
The rev and speed limiters on the Dodge cummins are very complex, we are working on rev limits but we have no dates nor definate answer if we will have them at this time.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
Streetsmoker
Streetsmoker
Just curious as to why it's so hard? I was told it's cause those two parameters are tied into the ecm's ABS and odometer signals to intentionally prevent them from being tampered with. I know you can bypass it all by pulling the ABS/VSS fuse but I hate that I have no speedo and due to not having a VSS signal, the tranny acts up sometimes. Heck, even Marco at Mad's Electronics (the Smarty people) haven't figured it out yet.
Streetsmoker
So thats why so many have given up on curing this probem. Everyone knows, that this is the only thing holding the Common Rail Cummins back.
'03 2500 2wd Reg cab HO
Stage-IV Goerend 48RE
Phat Shaft 62/14 Turbo
Edge Juice "Hot"/stacked w/Diablo Predator
70hp Dynomite Injectors, Glacier Flow LP w/Walbro GSL-392
536hp/1187tq #2 only (3/17/07)[email protected](4/27/07)
- duallydave
i tried removing the fuse and things were good but i had way less power.does the speed sensor effect the way the computer fuels?i have a stick so i had no tranny issues and i dont care about the speedo.i was just hoping for full power and no speed limiter.
