2015 F150
kellyfj10
Re: 2015 F150
Post by kellyfj10 »
sohfast94 wrote:
kellyfj10 wrote:
sohfast94 wrote:We found one locally that exhibits this. I'm getting it in here tomorrow and we'll see what we find.
Were you able to find out anything with the local tester?
Throttle does not die on the local one. Did have surging which was fixed in the latest tester that has been posted here previously.
If I load the latest tune, the gg, what do I do so you can see what is happening. will help anyway I can.
sohfast94
Re: 2015 F150
Post by sohfast94 »
Might as well make sure you're completely up to date.
trinity_ford_can_gas-1t13gl_update.crom
(3.57 MiB) Downloaded 351 times
Insert Clever comment here...
juangorena
Re: 2015 F150
Post by juangorena »
sohfast94 wrote:Might as well make sure you're completely up to date.
i´m going to install it , as son as i get a clue of how its working i will let you know , regards
juangorena
Re: 2015 F150
The truck is doing a lot of spitting and sputtering i used 93 performance, also you can hear like small explosion in the exhaust,
turbo kpa goes up and dow up and down at WOT ,
fuel consumption increased in a 40%
have you seen my previous logs ?? does this logs helps in any way ?
ZS.LOG
(152.67 KiB) Downloaded 334 times
71815.LOG
(365.02 KiB) Downloaded 478 times
kellyfj10
Re: 2015 F150
Post by kellyfj10 »
Loaded the tune in Friday, drove the truck on Saturday and Sunday, this morning lost all throttle in the middle of an intersection. I did not have my tuner hooked up so I did not get a log of it.
sohfast94
Re: 2015 F150
Post by sohfast94 »
juangorena wrote:The truck is doing a lot of spitting and sputtering i used 93 performance, also you can hear like small explosion in the exhaust,
Please read out the last tune written and post it. Also check plug gap as the logs look good and the truck is doing what it should be.
juangorena
Re: 2015 F150
I removed the tune from the truck since it didn´t behave correctly it increased the fuel consumption in a 40% also on the exhaust i found
Heavy carbon deposits , during the test check engine lamp pop up at intermitent cycles , today i´m going to try the 91 performance tune
FullSizeRender (2).jpg (389.73 KiB) Viewed 6928 times
sohfast94
Re: 2015 F150
Post by sohfast94 »
I would check plug gap
Roiceed
Re: 2015 F150
Post by Roiceed »
After 70 miles I lost all throttle response. So I guess back to the drawing board again.
juangorena
Re: 2015 F150
truck is only 4000 miles , should i suspect for a damaged spark plug or inadecuate gap cal ?
i tried the las tune with the 91 performance it seemed to work better but i los all throttle at a 30 miles of driving it , there is still a big issue there , the problem here is that you lost compeltely acceleration in the middle of the traffic :?
Roiceed
Re: 2015 F150
Post by Roiceed »
sohfast94 wrote:I would check plug gap
Check the plug gap? I would think by now you'd understand that the issue is on your end, not ours. :punisher:
sohfast94
Re: 2015 F150
Post by sohfast94 »
Emailed.
kellyfj10
Re: 2015 F150
Post by kellyfj10 »
Emailed.
Is there any fix for the throttle issue yet? not trying to pressure you, just excited to get it installed.
sohfast94
Re: 2015 F150
Post by sohfast94 »
Emailed.
juangorena
Re: 2015 F150
sohfast94 wrote:
Emailed.
Email it to me too ! [email protected]
Return to “Trinity Ford Gas”
