P.S. I get my pcm in tomorrow and cant wait to install it
2015 5.7 support
Re: 2015 5.7 support
Just thought you guys at diablo should know that you have the horsepower figures for the the 2015 cars and 2015 Rams mixed up. When you click on the 2015 cars,it shows the horsepower gains to be 33hp and when you click on the trucks it shows it at 15hp. Just thought you guys should know just incase someone dyno's it and gets way less than 33hp and complaines to you about it.
jim_maloney14
Any news on this update for on the 2015 Ram 1500?
15 Ram 5.7 is supported.jim_maloney14 wrote:Any news on this update for on the 2015 Ram 1500?
Two quick questions for you guys.......
1. Is support for the 5.7L in a 2015 Grand Cherokee definitely coming?
2. If it is, do you have an ETA?
Thanks in advance!
Thanks in advance!
Bump for an answer. Thanks.TheCRV wrote:Two quick questions for you guys.......
Thanks in advance!
yes, no.
Thank you!mikel wrote:yes, no.
fastzenner
Is there a chance the 2015 ram 1500 will be supported without a modified pcm?
No time soon...
fredafraid
Hi All,ISAACMAPLE08 wrote:Also ready to buy, Charger SRT 392. If you can answer, how does the PCM swap work in regards to warranty? Can Dodge detect if the PCM has been swapped back? Does it show the mileage on it or is that stored elsewhere? i.e. you get the car, swap to the custom PCM drive 3000 miles and take it back to the dealer after swapping in the OEM one does it show that you've driven 3000 miles or 20? I would think that might raise a few eyebrows?
Thanks for the hard work guys!
I have almost the same question but can't get relieved:
I have ordered and received a DS PCM and Trinity device: I have a '15 Challenger RT and I fear the swap.
I failed to understand why when purchasing we provide with the VIN and the mileage: it makes sense for the VIN but what about the mileage? Should the mileage / odometer be affected with the swap (like actual distance with the car is stored only in 1 PCM). Response was "no" in another forum / topic (Trinity Dodge Gas / 2015 5.7 support: https://www.diablosport.com/forum/viewt ... 4&start=60).
Eventually in my own situation, I have given the mileage in miles in the order form but I also added the comment that it equals xx in kilometers. Which one was set up - kilometers or miles?
DS support team,
could you please advise on this please?
Cheers
fredafraid
Hey again,fredafraid wrote:Hi All,ISAACMAPLE08 wrote:Also ready to buy, Charger SRT 392. If you can answer, how does the PCM swap work in regards to warranty? Can Dodge detect if the PCM has been swapped back? Does it show the mileage on it or is that stored elsewhere? i.e. you get the car, swap to the custom PCM drive 3000 miles and take it back to the dealer after swapping in the OEM one does it show that you've driven 3000 miles or 20? I would think that might raise a few eyebrows?
DS support team,
Cheers
Mike,
could you please advise please?
Anyone knows please?
Thanks and have a great day,
cheers
if you provide the odometer in KM, we will program it that way as well, no worries.
fredafraid
Thank you for the heads up Mike.mikel wrote:if you provide the odometer in KM, we will program it that way as well, no worries.
I'm fact I already ordered and received the PCM. I had put a comment when purchasing but I don't know if it was done.
Please tell me if it is important: my odometer is in KM. Will it change every time I swap the PCM? What will happen when I visit the service center? It won't be updated automatically?
I mean I'll service my car this coming Saturday. I commented I've done 20000 km and time to receive the PCM I am reaching 21000 km. Is it a problem?
I planned to swap after it: what will happen to my actual odometer and will I be able to do the service at 30000 km? Or the mileage is stored in the PCM only.. I must wait until my car is no more under warranty and proceed to servicing the car with 1 PCM only (the DS one).
Sorry if I am not clear..
Thank you for your inputs.
Cheers
I'm also trying to figure out if the mileage is stored in the PCM.
Does that mean every time you change from Factory PCM to DS PCM the mileage will be different?
No, it never changes, you'll never see the mileage change.
