D.O.D.??
hoorsec
D.O.D.??
Post by hoorsec »
Im doing some long distance highway driving now, and I put the M.P.G. booster tune on and thought the d.o.d. was automatic on? I had to turn it on, so is that sound rite? I did one trip already on the diablo tune and this time the m.p.g. tune,
hoping to see a bit of a difference still on 91, ...thank you.
Re: D.O.D.??
the mpg booster tune does have DOD/AFM enabled...
BUT..
if you had a different tune installed before and you disabled the DOD/AFM, then when you installed the MPG Booster tune if you did not RESET ALL PARAMETERS, then it will carry over your DOD disable change to the new tune you install...
so you should have RESET ALL PARAMETERS first when you installed the MPG Booster tune, so that your dod disable change didn't get carried over/applied to the mpg booster tune.
hoorsec
Re: D.O.D.??
Post by hoorsec »
thanks for the info, I did do a reset on both the ecm,tcm, so as long as its working fine on the truck it don't bother me, thanks again.
