Intune freezing
bullfrog69z
Intune freezing
Connect it to truck then everything work ok until I hit tune vehicle turn key on then the circle starts then hangs up. What the ****! Cain't even restore back to original. Any suggestions???
Re: Intune freezing
please give us a call with the tool powered up in the vehicle.
bullfrog69z
Re: Intune freezing
Just spoke to a guy name Mike. Went through the registry reset and installed a tune. Told me to send a copy of the back up and would send me a copy back to set it back to factory and from their I could tune again. Thanks for the quick response! Hope this works.mikel wrote:please give us a call with the tool powered up in the vehicle.
- ECM_12617301_BackupDiabloTune.grg
- (54.45 KiB) Downloaded 1093 times
Re: Intune freezing
drag/drop this file to the intine drive, let the tool import it, then go to the truck and select tune vehicle/write vehicle and it will prompt you to load this update, then you'll be back to stock.
- CTRL_12617301_UPDATE_3GTEK13348G112559.grg
- (50.84 KiB) Downloaded 1151 times
bullfrog69z
Re: Intune freezing
Thanks Mike!! Worked like a charm.mikel wrote:drag/drop this file to the intine drive, let the tool import it, then go to the truck and select tune vehicle/write vehicle and it will prompt you to load this update, then you'll be back to stock.
Re: Intune freezing
Mike,
My Intune freezes every time I start loading tunes or do check engine checks with my 04 Srt 4. Got anything to help me fix it?
Re: Intune freezing
freezes before it boots up?Eflip27 wrote:Mike,
Re: Intune freezing
mikel wrote:freezes before it boots up?Eflip27 wrote:Mike,
No it freezes when I click tune and the circle spins like it is doing something then the circle freezes.
sarah_ima64
Re: Intune freezing
Mike
I have the same issue with my intune can you help me ?
2008 silverado 5.3 4x4
thanks advance
thanks advance
- info.xml
- (2.2 KiB) Downloaded 947 times
- ECM_12621879_Backup.grg
- (57.74 KiB) Downloaded 1033 times
- TCM_24245713_Backup.grg
- (14.66 KiB) Downloaded 977 times
- runtime_00.dbg
- (548.18 KiB) Downloaded 1049 times
2005 RAM 1500 Daytona : Diablosport Trinity, CAI Airaid, Headers JBA, Catback Borla.
2009 RAM 1500 SLT 4x4 : Diablosport Trinity, CAI Airaid, headers JBA, Catback Flowmaster.
2011 RAM 1500 Laramie 4x4 : Diablosport Trinity, CAI Airaid, Catback Magnaflow.
Re: Intune freezing
go to settings/advanced/registry reset and type out the key and post it here and wait on that screen for my reply.sarah_ima64 wrote:Mike
thanks advance
sarah_ima64
Re: Intune freezing
My key is
619773
CE4515
B2A8BB
699C3D
173C62
619773
CE4515
B2A8BB
699C3D
173C62
Re: Intune freezing
click next then enter this
7D3E3A4C15FB90D4
then OK and it will reboot, then go to the car and tune it, and it will ask you to send ud the file it saves, post that here when you have it.
7D3E3A4C15FB90D4
sarah_ima64
Re: Intune freezing
I tried tune my silverado
I can't the intune said the truck was tuned with other product by DS
Re: Intune freezing
right, thats the file I asked you to post here for me.
sarah_ima64
Re: Intune freezing
Tune
- ECM_12621879_BackupDiabloTune.grg
- (57.36 KiB) Downloaded 996 times
