General Tuning & Factory Presets (Drive Modes)
General Trinity Support
klewand
Post by klewand »
I'm new to all of this.... I've got a 2015 Camaro ZL1
I have a few questions:
1 - Can Preset tunes be layered or is it just one at a time and your done?
2- Do Preset tunes effect factory drive modes? And do they over-ride Factory Modes?
(Five PTM performance levels or modes are available to accommodate the given ambient and track conditions, driver experience/vehicle familiarity and driver comfort levels. They include:
 Mode 1 – Traction control set for wet conditions, with stability control on and Magnetic Ride Control set on Tour.
 Mode 2 – Traction control set for dry conditions, with stability control on and Magnetic Ride Control set on Tour.
 Mode 3 – Traction control set on Sport 1, with stability control on and Magnetic Ride Control set on Sport.
 Mode 4 – Traction control set on Sport 2, with stability control off and Magnetic Ride Control set on Sport.
 Mode 5 – Traction control set on Race, with stability control off and Magnetic Ride Control set on Track. Launch control tuned for VHT-prepped drag strips.)
What are the best presets to use?
Thanks!
Re: General Tuning & Factory Presets (Drive Modes)
you cant change the behavior of the modes through the tune....
klewand
Post by klewand »
my question is: will a modified tune with the T1000 effect the Drive mode settings?
no, like he said, the tunes can not change the drive modes..
klewand
Post by klewand »
I have one more question... this is for 2015 Camaro ZL1 - the preset tunes are 93 oct. and 91 oct..
In Washington State premium gas in 92 octain. So what preset do I use?
Diablo can you make a 92 oct. Tune?
Thanks!
Id use the 91 tune, or load the 93 tune and log it to see how it likes it....
klewand
Post by klewand »
I also have a cold air intake I'm going to install. Are there any custom tunes for that? Any suggestions?
klewand
Post by klewand »
I need to ask, where do I find the spec details for the 2015 Camaro ZL1 tunes? Gas mileage, HP and Torque increases.
Redstripe
Post by Redstripe »
klewand wrote:I need to ask, where do I find the spec details for the 2015 Camaro ZL1 tunes? Gas mileage, HP and Torque increases.
http://old.diablosport.com/2015-camaro.html
if you select i2 or trinity on our site then select your vehicle, and scroll down, you'll see the available tunes and parameters, like this:
mov
Post by mov »
I recently purchased a Trinity Diablo from a member on the LX Forum and I was able to program everything except the tire size. I'd like to know if there's a limitation on tire size when programming the Trinity? I have a staggered set of 22's (Rear: 295/25/22) if that helps. Thanks!
klewand
Post by klewand »
I'm not able to find that for some reason and when I put my vehicle info up the 7.0L engine (I think that's a Z/28) is the only option I have a 6.2L engine. Please help thank you.
klewand
Post by klewand »
Never-mind I found it... Is there any gas mileage improvement?
Return to “General Trinity”
