Registration/ Update Problem
jlmtx2002
Post by jlmtx2002 »
Im trying to update my intune for the first time. After the updates are downloaded and the intune reboots I get a message saying updates cannot complete until devise is registered. I cannot figure out how to register my devise. Please help
Re: Registration/ Update Problem
please post the info.xml file from the intune drive.
jlmtx2002
Post by jlmtx2002 »
ok I think I added it
info.xml
(435 Bytes) Downloaded 421 times
jlmtx2002
Post by jlmtx2002 »
Any help
save this to the drive called intune and it will be registered.
registration.itf
(858 Bytes) Downloaded 394 times
jlmtx2002
Post by jlmtx2002 »
ok I believe I have updater the tuner properly. But I have apparently lost my original factory tune for my truck. Here is info.xml now
info.xml
(2.24 KiB) Downloaded 447 times
jlmtx2002
Post by jlmtx2002 »
Any suggestions on what needs to be done?
did it read a file out and ask you to email it to us?
post it here please.
jlmtx2002
Post by jlmtx2002 »
Is this what you need
ECM_12640859_BackupDiabloTune.grg
(60.17 KiB) Downloaded 432 times
jlmtx2002
Post by jlmtx2002 »
Was that the correct file?
yes, what vehicle is this specifically?
jlmtx2002
Post by jlmtx2002 »
It is a 2012 Chevy Silverado 1500 crew cab 4x4. 4.8L v8
save this to the intune drive and the tool will import it then you can go tot he truck and select tune vehicle/write vehicle and it will prompt you to load this to set the pcm back to stock.
CTRL_12640859_UPDATE_3GCPKREA6CG162407.grg
(56.57 KiB) Downloaded 553 times
hdspringer99
Post by hdspringer99 »
Mike,
Getting Check for a Calibration Update over and over. See attach info.xml.
Last time this happened you sent an update file that resolve the issue.
Dennis
info.xml
(3.74 KiB) Downloaded 477 times
