87 Octane tune - Rev Limit
ustommyboy
Post by ustommyboy »
I am trying to limit high Rev when towing with Tow/Haul and Cruise Control on.
When going up hills truck downshifts twice and revs almost to red line.
I reduce Rev Limit by 50; however it occurs to me I have no idea what that set it to.
What is the Rev Limit preset in the canned 87 Octane tune or how can I limit it to around 4500.
2001 GMC Sierra 1500 Extended Cab
V8 5.3L
Transmission Auto 4 Spd Hmd 4l60-e Electronic
Axle Rear 3.73 Ratio
LTX MS2 Tire P265/70R16
Windows 10 Pro
ustommyboy
Re: 87 Octane tune - Rev Limit
If this a ridicules questions or am I asking for privileged information, please say so. I would like to remedy this.
If its ridicules, please explain how I can remedy problem.
If its privileged information, please say so.
V8 5.3L
Windows 10 Pro
DiabloMatt
Post by DiabloMatt »
not privileged at all. what you would need to do is post up your last tune written and original backup off the tool. then i can open it and see where your rev limiters are. that being said if i understand you correctly, the rev limiters alone are not going to solve your problem. it will lower the rev limiter but it will still down shift and bang the limiter. you will need to lower the downshift speeds as well. that was you have to drop to a lower speed before it does downshift and the rpm wont be so hi after the shift.
ustommyboy
Thanks. Here they are. That all makes sense.
V8 5.3L
Windows 10 Pro
ustommyboy
Site won't let me upload.
V8 5.3L
Windows 10 Pro
ustommyboy
They are here for now:
http://tocoicreek.com/temp/
V8 5.3L
Windows 10 Pro
DiabloMatt
good deal... one sec
DiabloMatt
they show 6000 as factory and currently they are set at 5949.8
now just so you know this is a global rev limit not just in tow haul. i'll attach a tune that you can load as a custom tune any time you want to tow something is you want. you can then use the tool to modify my tune how you want. i'll set the rev limiter at 4500 like you wanted. and tweak the down shift. you can play with it from there.
DiabloMatt
there is something going on our end with the forum. do me a favor annd lets take this to email. also i need your TCM tune as well. i have your PCM file done.
email is [email protected]
ustommyboy
OK. It will be about ten minute or so.
I am trying to better explain.
V8 5.3L
Windows 10 Pro
ustommyboy
Where do I find the "TCM tune"
V8 5.3L
Windows 10 Pro
DiabloMatt
should be in the tunes folder. should have 4 files. two pcm and two tcm
disregard... just saw the year of vehicle... i have what i need
you have a 2001 truck.. there is no separate TCM on that old truck.. it's just the single PCM file for both engine/tranny...
DiabloMatt
06MonteSS wrote:you have a 2001 truck.. there is no separate TCM on that old truck.. it's just the single PCM file for both engine/tranny...
ya i wasnt paying attention lol
that was why i edited my post. lol
ustommyboy
Tune works Great.
Towed both boat and camper at around 63 MPH in Tow/Haul with Cruise Control on.
Camper stayed in 4th gear at about 1750 RPM with no down shifting.
Pontoon Boat (lots of air drag) stayed in 3rd gear at about 2300 RPM.
V8 5.3L
Windows 10 Pro
