I've been lurking but now I have an important question.
Hi gang...I know this has been asked a thousand times but is the use of a diablo predator traceable at the dealer? I have a 2004.5 Ram ctd. I have to drop it of today at the dealer for some serious work. I think the turbo is shot and the exhaust manifold is leaking like a mofo. Thanks in advance....
RE: I
Point blank YES!!!! Key counts are erased every time you program your truck with this unit. Even know the unit is advertised as being "undetectable" it is very easily detectable..
Sorry for the bad news.
Give me some info on how hard you were running.. What mods do you have?
President of C.O.P.A.D.S.
06' Cummins. 5'' Turbo back, DS+Puck, Edge Insight,Quad Boost Fooler, DCL Intake, MIA: Kitty, silencer Ring, tube guts and self control!!
Re: RE: I
Prolly gonna stir up a shit storm here but where have we advertised that this unit is undetectable?dclevey wrote:Point blank YES!!!! Key counts are erased every time you program your truck with this unit. Even know the unit is advertised as being "undetectable" it is very easily detectable..
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
RE: Re: RE: I
On the 03-05 models, you can add key counts after a reflash by simply turning the key on/off a bunch of times.
Re: RE: I
2004.5 ctd. K&N intake, muffler delete, isspro gauges(egt, boost and tranny) and my predator. I was jazzed to get my predator....I had to call the tech line a couple of times because my pred had to be updated....tech peeps were great. I have to admit though, I am dissapointed with the pred. I can barely run my truck in tow mode because the egt's get to hot while I'm towing my 5th wheel. I too, have idle issues in all three tunes and the truck runs like ass untill it warms up. I hope that some updates will come out soon to fix these issues...I just dropped my truck of at the dealer so I'm hoping they fix everything no quetions asked, we will see though.......keep your fingers crossed for me!dclevey wrote:Point blank YES!!!! Key counts are erased every time you program your truck with this unit. Even know the unit is advertised as being "undetectable" it is very easily detectable..
RE: Re: RE: I
The Granatelli/DiabloSport Predator hand held flasher tuner puts horsepower and torque increases at your fingertip. Nothing could be easier then installing a Granatelli/DiabloSport Predator. It requires no tools to install nor are you required to understand computers. No other hand held programming device offers as much horsepower and torque increases while at the same time incorporating a full diagnostic scan tool. While other comparable programmers can take to up to 30 minutes to transfer data, the Predator can accomplish the same goal in a little as 90 seconds. Then Predator will transfer precisely tailored tuning that will aid your vehicle in reaching it full horsepower and torque potential. Furthermore, for the enthusiast that demands everything, Predator even gives you the ability to tailor your tuning by allowing a 10% change in timing and 5% change in fuel enrichment up or down. Plus when going back to stock settings, only Predator scans your factory computer for trouble codes and erases them if you request. Predator can not void your factory warranty and once returned to stock settings leaves no "footprint" or "signature" to be traced by the dealer. Predator also comes with a limited Lifetime warranty.
U7131 Stock Vehicle Tunes:
60 RWHP and 130 lbs/ft TQ:Tow Tune, made specifically for towing. DiabloSport recommended weight limitations based on manufacturer suggested limits for the vehicle.
100 RWHP and 190-ft/lb TQ:Economy Performance Tune, designed for Economy and Performance, fuel economy depends solely on driving style, and will vary from vehicle to vehicle.
150 RWHP and 230-ft/lb TQ:Extreme Tune, designed for power and performance! DiabloSport recommends this tune not be used for towing.
180 RWHP and 280-ft/lb TQ:Extreme RKL Tune, designed specifically for opening a can of whoop-ass. DiabloSport recommends this tune not be used for towing. (Transmission Upgrade Recommended)
DiabloSport strongly recommends the use of larger diameter performance exhaust components and exhaust temperature gauges with the use of any performance diesel tuning.
U7131 Specific Features:
Custom tunes are supported and can be supplied for a gain of up to 180 hp
Internet Updateable
Increase fuel economy by up to 30% on economy performance tune (2-3 m.p.g.)
Unit automatically clears all trouble codes when the original backup is restored to the vehicle
Leaves no watermarks from the tunes meaning no warranty implications
Can read and erase fault codes, monitor live data and contains all specific "P" codes for this vehicle
Adjust for tire size changes
All standard DiabloSport Predator features
By DiabloSport
Internet Updateable
By DiabloSport
- ranger_dog
RE: Re: RE: I
Nice reply. Noticed you posted it 10 days ago. Haven't seen a rebuttal yet? Is the silence the sound of defeat??
Thanks, Ed 06 2500 QC 4x4 CTD, Auto, 3.73's, 275/70/18's, Thuren/Carli/Bilstein susp mods, 4 inch duals, K&N Filter, Modified intake, Predator & Puck, Quadzilla Cmdr & boost fooler, more to come.
Re: RE: Re: RE: I
we shouldn't have to turn the key on and off a bunch of times to get a key count up. this is an issue that should've been resolved before it was released. is diablosport going to pay to have a new ignition lock put in my truck when it wears out from turning the key on and off a bunch of times to get the key count up, i doubt it. i know you guys are busy and can only do so many things at one time, but you fixed this issue for the 7131 how about taking the time to fix it for the 7130 and then you won't have to deal with threads like these anymore.mikel wrote:On the 03-05 models, you can add key counts after a reflash by simply turning the key on/off a bunch of times.
05 2500 SLT, 600 cummins, 6 SPD, Predator/Puck Stack, Quad. Boost Fooler, ISSPRO Pyro and Boost, ISSPRO Turbo Temp Monitor, MBRP Exhaust, AFE Stg 2 PG 7, REESE rail setup for 5th wheel or The Goose, PJ Gooseneck 25 ft 14,000 GVW
Re: RE: Re: RE: I
Im not trying to be a jackhole, I just bought a product that did not nearly deliver the claims it had stated. I could not get away with it in my business. I would be taken to court!!!!!ranger_dog wrote:Nice reply. Noticed you posted it 10 days ago. Haven't seen a rebuttal yet? Is the silence the sound of defeat??
- ranger_dog
RE: Re: RE: Re: RE: I
I was complimenting you and saying diablosport was unable to respond to your pointing out that in fact they did advertise the predator as undetectable! Of course they can argue that they did not use the word "undetectable" but in fact said "leaves no "footprint" or "signature" to be traced by the dealer." IMO it means the same thing!!!
That text was not our text, it seems like the text is for a gasoline powered vehicle as it mentions timing and fuel user adjustable features, something that none of our diesel programmers feature. You have to understand how hard it is for us to police what people put up text wise for our product.
Now that we fixed this issue, a little late i agree, this should not be a concern anymore. We will get to the 7130 shortly.
Diablosport INC
Diablosport INC
dodge_deisel
So this question might have been asked before, but is there going to be live data on the 7131 tuner?
Re: RE: Re: RE: I
That is hilarious!!!mikel wrote:On the 03-05 models, you can add key counts after a reflash by simply turning the key on/off a bunch of times.
I downloaded the r14 to get the shift-on-the fly option I bought and have not many problems yet. Now that they have the key count issue taken care of I have to decide what option I will have to give back. I bought both options though...
WAIT!!!! I can hire a day laborer for a day to turn my key on and off!!!
Hmm.. Two years from my last factory flash...... 712 days at least two cranks a day...1412.....stopping at the store, fuel, ect.,ect.,,
1600 key turns
Cool! Thanks for the idea. I got everything covered now!
Re: RE: Re: RE: I
By Diablosport?dclevey wrote:The Granatelli/DiabloSport Predator hand held flasher tuner puts horsepower and torque increases at your fingertip. Nothing could be easier then installing a Granatelli/DiabloSport Predator. It requires no tools to install nor are you required to understand computers. No other hand held programming device offers as much horsepower and torque increases while at the same time incorporating a full diagnostic scan tool. While other comparable programmers can take to up to 30 minutes to transfer data, the Predator can accomplish the same goal in a little as 90 seconds. Then Predator will transfer precisely tailored tuning that will aid your vehicle in reaching it full horsepower and torque potential. Furthermore, for the enthusiast that demands everything, Predator even gives you the ability to tailor your tuning by allowing a 10% change in timing and 5% change in fuel enrichment up or down. Plus when going back to stock settings, only Predator scans your factory computer for trouble codes and erases them if you request. Predator can not void your factory warranty and once returned to stock settings leaves no "footprint" or "signature" to be traced by the dealer. Predator also comes with a limited Lifetime warranty.
Internet Updateable
By DiabloSport
Sure this isn't from Granatellis website, since I know for a fact we have NEVER used the term Granatelli in any of OUR literature.
