99 v6 mustang converted 02 4.6l 2v
robb426
Post by robb426 »
cranks but will not start, im assuming it the pats system. can the scanner bypass it , and if so , will i need to buy any thing else with the scanner. i have the engin wiring harness and computer that was in the car with the engin
christina
RE: 99 v6 mustang converted 02 4.6l 2v
Post by christina »
You will need to get a custom tune from a CMR Dealer to disable the PATS.
Christy High
lurker.
robb426
Post by robb426 »
CMR dealer???, i jjsut got a steering column with key and computer from the same car and installed it, but it still cranks but does not start, has fuel psi, hooked up noid lite to injector it did not blink when cranking engin.
Talerno
Post by Talerno »
robb426 wrote:CMR dealer???
Go to the Dealer locater at the top of the page.
robb426
Post by robb426 »
when converting 99 to 04 mustangs u will need....
1. key
2. ign cylinder
3. computer
4. instrument cluster
ALL FROM THE SAME VEHICLE.
they are all part of the security system. once i got all those together the car started on the first try. this link helped me out a lot.
http://www.carquest.com/common/download ... lletin.pdf
Return to “Predator Ford Gas”
