i2 91 octane flash problem
mhoferitza
Post by mhoferitza »
Dont know if I am doing something wrong. Just got the tuner and up dated it on the computer. I did the whole pcm process and then did the 91 flash and tried driving the car (only took Rev limiter off). Car will not accelerate, seem like it is losing signal to the throttle body. Any ideas? 14 challenger rt 6speed
Re: i2 91 octane flash problem
try loading the tune with no rev limit changes, it should work fine for now.
tduvall
Post by tduvall »
Same here, I have a 2014 Dodge Charger R/T Max and with the "REV Limiter" diabled when you press on the gas pedal it will kill the engine. Went back and installed the 'REV Limter" and it seems to work. :(
thanks, we've seen this as well and are fixing it now ;)
do you guys mean SPEED limiter through the easy tune menu?
There is no REV limiter disable....
please post the info.xml files from your i2 drives.
