Issues on my 2014 300
Tried to install unsuccessfully. It's a 2014 Chrysler 300 with push button start. Is there an issue with these on push button start cars?
Re: Issues on my 2014 300
yes, remove the push button and use the key
Ok, and how is that done? I just want to be able to tune my car
simply pop the push to start button out as described in the quick start guide that comes with the tuner
According to the start guide, chryslers do not have a removable push button. That is noted for the charger. And putting it in run isn't working.
its removable for 11-14 models.
adfurgerson
Not looking at this manual it doesn't show a way to remove. Too big to upload directly here.mikel wrote:its removable for 11-14 models.
https://app.box.com/s/pljv6v4mz0sqw0n2cco4qj7j1y6zl41ff
Edit.......the fob doesn't have an end that can be used as a key.
OK, yeah, that one does not come out.
if this a V6?
VIN?
if this a V6?
VIN?
5.7 hemi
2C3CCABT5EH120045
2C3CCABT5EH120045
OK, have you tried starting from scratch ensuring run mode is enabled?
