TPMS Threshold Shows 0 PSI and do not update
justo_y_franco
Post by justo_y_franco »
Hello,
I have a Jeep Wrangler 2012 and a few months ago I noticed that the TMPS threshold, which I had at 28 psi, now shows 0 PSI. I tried to set it up to 25 PSI and apply the change , but each time I tried the tuner gives me the following message: "Successfully updated (null)". When I go back and check it still has it at 0 PSI. Nonetheless, my JK gives me the "Low Tire Pressure" so it seems the tuner did not make any change.
I attached the info.xml and last tune.
info.xml
PCM_68138815AF_LastTuneWritten.drg
Aside from this problem the tuner works perfect.
Thanks in advance for your help.
Re: TPMS Threshold Shows 0 PSI and do not update
try restoring the stock tune to the truck, then retune it and try the changes again.
justo_y_franco
Thanks, I restored the stock tune, went to the TPMS Threshold, still showed 0 PSI and when I changed it still gives me the "Successfully Updated (null) message" and did not make any change. These are my latest files from today.
What's next?
justo_y_franco
Mikel,
Any update on this?
I have not seen ths behavior, so Im not sure how to resolve it. The latest updates had it all working properly, but it may be an issue with the old version that messed it up and it may need a dealer config to set it back correctly.
justo_y_franco
Thanks Mike. How we can do this dealer config?
justo_y_franco
Could you answer my question? Thanks.
trax95008
Post by trax95008 »
OP, this is typical of Mikel. when it gets to the point of taking responsibility for their tuner causing problems, he disappears. i have multiple threads left unanswered as well
justo_y_franco wrote:Thanks Mike. How we can do this dealer config?
ANy dealership will have the knowledge to reconfigure the vehicle settings for sure.
trax95008 wrote:OP, this is typical of Mikel. when it gets to the point of taking responsibility for their tuner causing problems, he disappears. i have multiple threads left unanswered as well
post a link to these threads.
I've been out of the office for a week, unable to respond to the forum.
justo_y_franco
Ok, but the problem is not with the Jeep factory settings, It's the intune that is not reading the TPMS and doesn't make any update. How can I reset the intune?
trax95008
Post by trax95008 »
both of these are left unanswered/unresolved
https://forum.diablosport.com/viewtopic ... 57&t=53076
https://forum.diablosport.com/viewtopic ... 57&t=51549
justo_y_franco
Mikel,
Can you answer my question?
it should not need to be reset.
if it is not reading the tpms settings we'll need to look into it on our end.
SOMD_jeep
Post by SOMD_jeep »
I'm having a similar issue with inTune not being able to change the TPMS setting on a 2014 Jeep Wrangler. It is set at 35psi and when I attempt to change it comes back with "Successfully Updated (null) message" and did not make any change.
I can turn the TPMS sensors on and off, but I cannot change the TPMS threshold.
Interested in any updates that might correct this issue.
