I-1000-DCX/ Register
Freakzilla
Hi guys!
I´m a new proud owner of a I-1000-DCX in Vienna, Austria.
After updating the device, the registering screen was popping up on the PC.
However, i couldn´t complete the registration, because my postal code seems to be invalid - i guess, cause i´m located in Austria and not in the US.
Do i need the InTune registered to use it?
If so, how can i get it done?
Any help would be appreciated.
Alex
Alex
Re: I-1000-DCX/ Register
please post the info.xml file from the intune drive
Freakzilla
Sure - uploaded it!
But the main question is...
can i use the device without registering it or is registration a must in order to use it?
yes, its up to date and ready to go.
save this to the intune drive and the device will be registered.
Freakzilla
OK, will do that - thanks!mikel wrote:save this to the intune drive and the device will be registered.
Freakzilla
Saved it, the device restarted and now i don´t see the registration file on the device anymore!mikel wrote:save this to the intune drive and the device will be registered.
I guess this is supposed to be that way, right?!
Just out of curiosity:
Will this file work on other devices as well - cause it seems the file has been downloaded 7 times.
Not by me!
What can anyone possibly want to do with my registration file???
that reg file is for you only
Hi Mike,
Need the registry file also. Here is my file
Hope to get it soonest
Hi Mike,Pmexpert wrote:Hi Mike,
Any chance to get the registry file? Need to adjust tire size...but still cannot use my inTune DCX
registration does not preclude use of the tool....
here you go.Pmexpert wrote:Hi Mike,
It doesnt seems it is registered, as Licensed 0/1 is showingmikel wrote:here you go.Pmexpert wrote:Hi Mike,
And it says PCM need an update when connected to the truck(2014 RAM 1500)
licensed is married status, nothing to do with registration.
If it imported the file it is registered.
Thanks for the info, Mike!mikel wrote:licensed is married status, nothing to do with registration.
What about PCM updating? What should I do with that? Sorry for these questions, I never met such issues with Trinity on my GM truck previously
And I still have this message...
