Trinity not reading PCM 2005 Escalade 6.0 swap
greychevy
Post by greychevy »
I have a trinity that works flawlessly on my 2012 Dodge Ram. I just swapped a LQ9 from an 05 escalade into a 92 k1500. I wanted to use the trinity to read codes and datalog the k1500. When I plug it in it will power up but not recognize that the vehicle is running if I try to log and not recognize that the key is on if I try to read codes. I have an actron scanner and it works fine for reading codes and viewing parameters on the k1500. Any idea why the trinity is doing that but the actron works fine? The truck is HP nelson tuned and I need to get some datalogs ASAP. Thanks!
Ethan
First & only 4th gen 4x4 in the 12's NA 12.747 @ 104.07
2012 Black SC 4x4 1500 Hemi, Coated ARH longtubes, Vararam intake,
Circle-D, efan, 2010 frontend swap/4.56 gears, Trinity w Greene Racing tune,
Moe's 87mm throttle body, AEM Wideband
Re: Trinity not reading PCM 2005 Escalade 6.0 swap
gotta change vehicle type under options/change vehicle type first...
greychevy
Post by greychevy »
Lol well, that was easy. I've had it on my ram for so long I don't even remember doing that when I first installed it. Thanks man!
Ethan
Return to “Trinity GM Gas”
