Cant get I2 to install to vehicle
majesticmotorsports
Post by majesticmotorsports »
Im trying to get a 2010 to install on a dodge magnum and when I select ez tune and 89 octane and use tune the circle stops and it doesn't do anything. If I go to advanced it wont let me get that far and everything is greyed out. I got a message one time that this vehicle isn't supported but when I try to run the updater it says there is no updates avaliable
Re: Cant get I2 to install to vehicle
Im emailing you an update to try, please save it to the i2 drive, let the tool import it then try again.
majesticmotorsports wrote:[email protected]
I sent it a while ago to the email you are registered to, [email protected]
resent to mike@
majesticmotorsports
it is .net not .com
I corrected it, it has been sent to both addresses.
majesticmotorsports
We still haven't received anything.. [email protected] or [email protected]
its a large file, it may be getting blocked on your end.
Too large for me to host it here on the forum, do you have a different email address?
majesticmotorsports
I tried to use a i1000 we had in stock and it has a error when trying to update pcm 04896405AQ and says to contact tech support
majesticmotorsports
you can try that one.
Last edited by majesticmotorsports on Fri Oct 23, 2015 10:50 am, edited 1 time in total.
majesticmotorsports wrote:I tried to use a i1000 we had in stock and it has a error when trying to update pcm 04896405AQ and says to contact tech support
was it a normal I-1000 or I-1000 dcx?
Post the info file from that tool please.
majesticmotorsports wrote:[email protected] you can try that one.
sent...
majesticmotorsports
got the email this time,, it is a i1000 dcx
<?xml version="1.0"?>
-<tool_info>
<main svn="8521" sw_rev="1r04i" full_version="InTune-1r04i 08/03/2015 01:32:36 PM"/>
<registration status="0" sn="J2AI5E2-4"/>
<cal_id CM1="04896395AFke0r0" PCM="04896405AQ"/>
<restore bc="0" vin="2D4GV582X5H117299" id="0"/>
<system_db vin="1r01e" dtc="1r01a" info="1r01b"/>
<db pid="1r01b" tune="1r01u" mfr="DCX"/>
<db pid="1r01b" mfr="FORD"/>
<db pid="1r01a" mfr="GM"/>
<license tuned="0" avail="1"/>
<unsupported vin="2D4GV582X5H117299" oem="DCX" calid="04896405AQ"/>
<updates count="3"/>
<oem tool_oem="DIABLODCX"/>
<reg reg="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"/>
</tool_info>
the dcx is for 11+ models, what year is this car?
