2014 5.3 chevy
Egoresb
Re: 2014 5.3 chevy
Post by Egoresb »
I can try skipping the tcm tune I haven't tried that. I always just did modified stock but never fooled with the preloaded settings. I'll try that and let you know.
Egoresb
Re: 2014 5.3 chevy
Post by Egoresb »
Got the 87 oCtane canned tune loaded no changes. Skipped tcm tune all together as requested. Still getting the banging shift at 100% WOT. I'm really at a loss now. Although I understand the PCM and tcm work together to find the proper shift points/pressure I'm not understanding what's going on here. Does it without any throttle boost added on my end.
Would really like to get this thing working properly so I can have the extra power as I'm putting a small lift and larger tires within the next 2 weeks.
Egoresb
Re: 2014 5.3 chevy
Post by Egoresb »
Would my issue possibly have anything to do with my drop in k&n intake filter? Just a factory replacement not a intake kit.
Re: 2014 5.3 chevy
OK, did you restore then reload and skip the tcm?
if not whatever you last loaded to the tcm is still there....
Re: 2014 5.3 chevy
does it do it stock??? maybe you got a bad tranny? a LOT of people have that issue with those trannies.. http://www.gminsidenews.com/forums/f53/ ... ms-164881/
Egoresb
Re: 2014 5.3 chevy
Post by Egoresb »
No issues whatsoever stock. Shifts nice and smooth under light and heavy throttle even pulling heavy loads even 100% WOT, no issues whatsoever. And yes I restored original tune then installed just the PCM tune and skipped tcm tune install.
Re: 2014 5.3 chevy
OK, we're on to something.
Post the current files from the tunes folder and the current info file please.
Egoresb
Re: 2014 5.3 chevy
Post by Egoresb »
They are posted previously in this thread. Nothing has changed. The truck is back on factory tune for now. I believe the file I uploaded previously had +15% throttle boost.
Re: 2014 5.3 chevy
OK, Im not trying to give you a hard time, but would you please post the current files from the tunes folder, and the info file?
If you restored and reloaded Id like to see whats there now.
Egoresb
Re: 2014 5.3 chevy
Post by Egoresb »
Ah ok. Just thought you may have been able to use the old files. I will upload them tonight for you.
Egoresb
Re: 2014 5.3 chevy
Post by Egoresb »
as requested. here are all the files on the device. 87 octane canned pcm tune unaltered and no tcm tune was installed.
TCM_24271132_Backup.grg
(53.27 KiB) Downloaded 222 times
info.xml
(2.42 KiB) Downloaded 233 times
ECM_12659743_LastTuneWritten.grg
(111.97 KiB) Downloaded 243 times
ECM_12659743_Backup.grg
(111.31 KiB) Downloaded 254 times
Egoresb
Re: 2014 5.3 chevy
Post by Egoresb »
Jeez y'all have a spambot issue on this forum. Thanks for deleting all the unneeded garbage in this thread. Any update on my issue?
Re: 2014 5.3 chevy
try loading this tcm tune with the same pcm tune and let me know if its good.
TCM_24271132_test.grg
(46.25 KiB) Downloaded 238 times
Egoresb
Re: 2014 5.3 chevy
Post by Egoresb »
first to 2nd seems fine all other gears still bang pretty hard at WOT.
TCM_24271132_LastTuneWritten.grg
(53.32 KiB) Downloaded 207 times
(53.26 KiB) Downloaded 209 times
info.xml
(2.42 KiB) Downloaded 213 times
(111.96 KiB) Downloaded 177 times
(111.31 KiB) Downloaded 224 times
Re: 2014 5.3 chevy
Hmm...I will need to look at the files, ALL I changed inthe tcm tune was to let it shift a little harder for 1-2, didnt touch anything else...
