2015 Eco Boost Dead peddle Info Thread.
sqeegee
Re: 2015 Eco Boost Dead peddle Info Thread.
Post by sqeegee »
2015 F150 FX4 3.5 Ecoboost
Here is my last tune using I1
Would like a 87 tune
info.xml
(1.9 KiB) Downloaded 292 times
juice055
Post by juice055 »
not sure what one you need so here you go this is the 87 tune
PCM_PKCMAW3_LastTuneWritten.frg
(165.47 KiB) Downloaded 331 times
info.xml
(1.97 KiB) Downloaded 327 times
DiabloMatt
Post by DiabloMatt »
juice055 wrote:not sure what one you need so here you go this is the 87 tune
juice055.....here is yours. please try it out asap.
save that file and load it into tool as custom tune. then flash into truck.
pcm_pkcmaw3_TEST.frg
(145.71 KiB) Downloaded 291 times
DiabloMatt
speegee: i need you to physically load the tune you want into the truck first. then attach the "last tune written" out of the tool so i can modify it.
juice055
Post by juice055 »
Installed tune and still have no pedal
DiabloMatt
juice055 wrote:Installed tune and still have no pedal
ok please post the last tune written again.
juice055
Post by juice055 »
here you go
DiabloMatt
juice055 wrote:here you go
ok let me see. thank you
sqeegee
Post by sqeegee »
ok, try this on
looking for a 87 tun
PCM_PKCMAH2_LastTuneWritten.frg
(165.45 KiB) Downloaded 298 times
kellyfj10
Post by kellyfj10 »
Matt,
I sent you a PM with a suggestion in it. Let me know if you are interested.
Frank
kellyfj10
Post by kellyfj10 »
Matt,
Here is my last tune written. see what you can do. I have a trinity
I sent you a PM also
PCM_PKCMAW3_Premium_Fuel_Performance_.frg
(9.25 KiB) Downloaded 332 times
DiabloMatt
kellyfj10 wrote:Matt,
kelly can you save this on your tool as a custom tune and load it in your truck please. it has some changes based on what you described to me.
TEST_.frg
(145.06 KiB) Downloaded 264 times
kellyfj10
Post by kellyfj10 »
Installed the tune. Dead pedal first key turn.
DiabloMatt
ok next thing..... can you please post your original backup tune. i have something else up my sleeve.
kellyfj10
Post by kellyfj10 »
Here is my backup file
PCM_PKCMAW3.frg
(193.39 KiB) Downloaded 282 times
Return to “General Support”
