2015 GMC Sierra 5.3 4x4 E85 Tune
Kchambliss69
Post by Kchambliss69 »
I have an intune 1000. I did an auto update on the tuner today, and was looking fwd to running the new e85 tune that I had read about on a silverado/sierra forum. Unfortunately when i hooked the tuner up to my vehicle it only had the following tunes, the diablo tune, 87 Octane, mpg booster and modify stock tune. It did not have the scroll up or down arrows on the screen (which told me those were the only tunes on the device.) I have not yet downloaded the physical file from the website for the gm tune update yet, as I wanted to get confirmation or more information on this subject. Any help would be greatly appreciated in this matter. Also, will the tcm tune be included in the e85 tune or will that be a seperate file. I've looked all over the internet and ofcourse youtube trying to find more information on these topics and the tuning of the new l83 engine but there is limited information out there. If anybody knows of some links that could help me out I would also appreciate that. Hope to here from u guys soon. Thanks
Re: 2015 GMC Sierra 5.3 4x4 E85 Tune
Please post the info.xml file from the intune drive.
I believe all 5.3 models are flex fuel, so the tune should be there.
It's there for 2014's Mike, but not for 2015's for some reason.. Have seen this many times with new 2015 truck guys..
Kchambliss69
Thanks for the info 06MonteSS. Is there a way to email the e85 tune to me, or is there more to it? It will b an hour or so before i can post the info file if it is still needed. Glad im not the first person to run into this issue.
Kchambliss69
Here is the info.xml file content.
<tool_info>
<main full_version='InTune-1r04i 08/03/2015 01:32:36 PM' sw_rev='1r04i' svn='8521'/>
<registration sn='KUG6K91-8' status='0'/>
<cal_id PCM='12664769, 12664263, 12665173, 12653630, 12659034, 12659078, 12659172, 12664527' CM1='24270599, 24271221, 24274447, 24271222'/>
<restore id='0' vin='3GTU2UEC3FG110485' bc='0'/>
<system_db info='1r01b' dtc='1r01a' vin='1r01e'/>
<db mfr='DCX' tune='1r01e' pid='1r01b'/>
<db mfr='FORD' tune='1r02c' pid='1r01b'/>
<db mfr='GM' tune='1r02q' pid='1r01a'/>
<license avail='1' tuned='0'/>
<updates count='1'/>
<oem tool_oem='DIABLO'/>
<reg reg='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'/>
</tool_info>
Kchambliss69
Just checking to see if you guys have any update on this topic. Not trying to rush, just like to see what my options are at the moment. Again thanks for the help.
Turns out not all 15 5.3s are flex equipped from GM....
Kchambliss69
Ok, so how do I go about getting the tune for my vehicle seeing as how it is a flex fuel engine?
Post your backup file please.
Kchambliss69
Ok, I haven't tuned the truck yet due to the fact that I was wanting to run the e85 tune, but if thats what is necessary for me to get the e85 tune I will be able to do it later tonight. What tune would you recommend me installing to create a backup file?
you HAVE to install a tune to the truck so that the tool saves copies of the original backup stock tune file in itself.. so yes, you HAVE to install a tune..
you can install the Diablo Tune and run it just fine on e85 fuel.. so no worries there..
Kchambliss69
Ok thanks. I'll b sure and post the backup file tonight when I get a chance.
Kchambliss69
Here is my backup files.
ECM_12665173_Backup.grg
(114.5 KiB) Downloaded 916 times
did you want the 87 flex or 91/93 flex tune?
Kchambliss69
I was under the impression that you had a stand alone e85 tune. But if not, out of those two options I would prefer the 91/93 flex tune.
