04 chevy "read failed" and driver issue on pc
mtjeeves
Post by mtjeeves »
I just got my I2 for my 2004 Silverado 2500hd 8.1. I plugged the tuner in, turned on the key. It goes through it's process, has me turn the key off and hit continue, then turn the key on and hit continue. Then it gives me a message that the read failed. Then it froze up and I'm afraid to move my 8,917lb truck for fear it will be stuck somewhere if I do. I tried connecting the tuner to my computer using the instructions (which are vague), and my computer will not even recognize the unit as plugged in. I checked the forum out before posting and see that for the first problem I am not the only person with this issue. I haven't however seen anybody else with a tuner that the computer will not recognize. Any suggestions?
mtjeeves
Re: 04 chevy "read failed" and driver issue on pc
Post by mtjeeves »
So I had to restore my pc to before I plugged in the i2. Then the computer recognized it. I tried to use the update tool and it informed me that I needed to insert another file and I have the wrong one. So I went to apply it to the truck again, applied tire size and set to diablo tune. It installed. So after that I went to adjust speed limiter. Same problem occurs. it fails. so instead of reloading stock setup. I had it create a log. I check the folder for the I2 on the computer labeled logs, and there isn't one. I did find two files in the "tunes" file and I uploaded them. :drivingbad:
mtjeeves
Post by mtjeeves »
So I tried the tuner again with no changes and we're back to square one. With a twist. Now when the tuner fails, it also fails to re-write the vehicle back to stock. Now my truck doesn't start and the menu just reads "reduced engine power". I kind of need my truck, and this isn't helpful at all. Hope somebody gets to this soon because I have to be back to work on Thursday.
so it will not restore and it does not start currently?
is the tool in recovery mode?
mtjeeves
Post by mtjeeves »
yeah that tool was in recovery mode, and would not load the stock tune. The truck tries to turn over, but doesn't fire.
save the attached update to the i2 drive on a pc and let it import it then take it to the truck and try the restore again please.
mtjeeves
Post by mtjeeves »
It took about 10 minutes for it to install the update. Took it out to the truck. Was no longer operating in it's safe mode and just came up with a menu for applying a tune. So I applied the tune. The first two times it said it was unable to identify reading parameters. Then on the third time it went through. Now the truck starts, but it runs like shit and wont allow the engine to rev above 1,400 rpms. With the way it's running I wouldn't want it revving any higher anyhow.
what did yo uload?
Did you make any chnages when yo uloaded it?
Is it ok after it restored?
mtjeeves
Post by mtjeeves »
So after attempting to get it to write back to stock 7 times it finally wrote it. The truck seemingly runs fine now on the stock tune. That doesn't solve the issue that I seem to have a 400 dollar paperweight though. I don't understand what's wrong with this thing. I have an intune on my 08 charger and have never had a single problem, and thought your tunes were way better than what hypertech had to offer. I've got the numbers to prove it too. That's why I bought one for gm vehicles for my truck. Let me know if you need anything else from me I guess. I'm waiting on hold on the phone to talk to you guys.
We're closed for the evening.
Pleas epost the current info.xml file so we can sort htis out.
mtjeeves
Post by mtjeeves »
Glad I sat in my truck for an hour on hold, which I might add I'm still on hold.. I hope this is the file you need because There's nothing else to attach.
which tiune did you load, and did you make any changes?
There is nobody in the office, please dont stay on hold, we closed at 6:00 PM EST.
mtjeeves
Post by mtjeeves »
I tried to load the 93 octane tune and when it actually loads and doesn't fail. The truck runs like crap and is in reduced power mode and wont go higher than 1,400 rpms. That's without changing anything and just letting it install. If I try to change anything other than tire size it wont write the tune, or freezes up. I'm running an 8.1/Allison combo with cold air intake and headers.
mtjeeves
Post by mtjeeves »
So after getting no response. I re-installed the file to the tuner. It doesn't seem to have any problems writing or reading now. As long as I don't change anything. The only problem now is the diablo tune is garbage. The motor chokes out at 1,700 and takes about 3 seconds to accelerate past that like it's either not getting fuel or air. The truck literally runs like it's on it's last leg unless it's on the stock setting. Maybe you guys need to look into your 8.1 tune, because what we've got now. Isn't working. I wish we could just do an android app and a cable instead of proprietary hardware that I'm not sure has been working right all along. I have no idea for sure if it's the tune, or the unit, but something isn't working.
mtjeeves
Post by mtjeeves »
Here's everything I could attach.
