Enjoying the Diablo Tune
08Z51Guy
Post by 08Z51Guy »
I'm lucky enough to have a 2008 Z51 manual transmission convertible. There were only 923 made in 08, and it was kept in pristine. The biggest complaint I had was lack of grip, so I've swapped the 285/45r19s for 305/30r19s. Your tuner was key to speedo adjustment. Thank you everything is spot on.
Given the option, I installed Diablo tune (as opposed to 91 octane or modify stock tune) and am happy with the performance gains. That said there seem to be several aspects of the tool that I'm not utilizing. Who do I work with to dial in multiple tunes? If I want to lean out my afr, and advance the spark how far and what should I adjust?
While I log, or record the data, what data points should I examine to dial in the tune?
Thanks in advance. I appreciate any insight.
Corvette Screenssaver.png (266.12 KiB) Viewed 1558 times
Re: Enjoying the Diablo Tune
There s a great write up here, explaining how to interpret the log data and make changes:
https://forum.diablosport.com/viewtopic.php?f=26&t=917
08Z51Guy
Post by 08Z51Guy »
That was the perfect article. Thanks for the reference material.
Will the DSLOGREDUX program make suggestions for timing and will the adjustments be in a language that translates to the T1000?*
*I don't think the DSLOGREDUX program will write the changes to the tune, just wondered what the recommendations looked like
no, it doesn't do anything for timing suggestions..
