2015 F150 Ecoboost not working.........
LAFNGAS
Post by LAFNGAS »
I had the trinity married to my srt8 jeep, i set it back to stock then updated the trinity via the newly downloaded dsdownloader. From there i changed the vehicle to the ford f150 and put it into the truck. then it stated it needed a calid update so i rehooked it to the dsdownloader. then it worked and installed the tow tune and was completed. i started the truck and went to go somewhere but it would do nothing but start/idle and even hitting the gas pedal there was no revs even when the gear selector was put into neutral.
i did put the original backup tune in and truck works great, i did not try to install any of the other tunes as i needed to use the truck.
oddly enough there was no option for the mpg tune, just was the tow/93/91/87 and modify stock file
DiabloMatt
Re: 2015 F150 Ecoboost not working.........
Post by DiabloMatt »
LAFNGAS wrote:I had the trinity married to my srt8 jeep, i set it back to stock then updated the trinity via the newly downloaded dsdownloader. From there i changed the vehicle to the ford f150 and put it into the truck. then it stated it needed a calid update so i rehooked it to the dsdownloader. then it worked and installed the tow tune and was completed. i started the truck and went to go somewhere but it would do nothing but start/idle and even hitting the gas pedal there was no revs even when the gear selector was put into neutral.
it appears you have one of the cal ids that are effected by dead peddle. we have thread going already full of information. we are very close to having this fixed. post up in there :)
https://forum.diablosport.com/viewtopic ... 16&t=51870
fix attached!!
update tool with this crom then reload the tunes :)
trinity_ford_can_gas-1t13la_update.crom
(3.85 MiB) Downloaded 395 times
LAFNGAS
Post by LAFNGAS »
will this work for all tune files?
LAFNGAS
Post by LAFNGAS »
update didn't work, instant dead pedal, here are the original backup and the one that was installed
PCM_PKCMAK4_DiabloSport_Towing.frg
Diablosport 87 octane tow tune
(9.25 KiB) Downloaded 313 times
PCM_PKCMAK4.frg
original backup
(193.41 KiB) Downloaded 321 times
sohfast94
Post by sohfast94 »
Here you go this should fix it.
trinity_ford_can_gas-1t13lf_update.crom
(3.86 MiB) Downloaded 338 times
Insert Clever comment here...
LAFNGAS
Post by LAFNGAS »
sohfast94 wrote:Here you go this should fix it.
even the towing tune will give the 50hp/70tq bump in power correct or will it just adjust transmission shifting?
DiabloMatt
it bumps the power too
:mrgreen:
LAFNGAS
Post by LAFNGAS »
:mrgreen:
yeeeeeeeeeeeeep sure does, i know some tow tunes adjust shifting but yeah, noticeable difference for sure
cheers!
Return to “Trinity Ford Gas”
