Cannot register Intune
wgerickson
Re: Cannot register Intune
I think i went to the right website to register my Intune, what happens after that do i receive a file or something, i have tried updating the intune and says it cant till it is registered.
I bought it few years back and found out it will work with my truck i have. So want to use it for towing.
my email is [email protected]
thanks
Bill
thanks
Bill
I have emailed you a request for your info file so I can complete the registration. Send it when you can, and I'll handle it for you.wgerickson wrote:I think i went to the right website to register my Intune, what happens after that do i receive a file or something, i have tried updating the intune and says it cant till it is registered.
thanks
Bill
deadcatsrule
I can not register my intune aswell
- info.xml
- (2.33 KiB) Downloaded 873 times
14SilveradoWidow
I cannot register mine as well. One of a plethora of problems I'm having. Please help!
- info.xml
- (2.1 KiB) Downloaded 822 times
save this to the intune drive.14SilveradoWidow wrote:I cannot register mine as well. One of a plethora of problems I'm having. Please help!
- registration.itf
- (377 Bytes) Downloaded 971 times
attached.deadcatsrule wrote:I can not register my intune aswell
- registration.itf
- (377 Bytes) Downloaded 907 times
deadcatsrule
that worked,thanks
Can't get it to register.
- info.xml
- (1.67 KiB) Downloaded 891 times
Shaneous69
Just got my I2 yesterday and when I try to update it, I get
"unexpected error has occurred: Registration unable to locate file E:/info.xml
Object reference not set to an instance of an object"
Cheers,
Shane
Cheers,
Shane
Greetings!
I just purchased an i1000 and updated it to the 1r04i firmware via the updater program. I have already registered my device but once I boot the updater after all of the updates have been completed I get a blank error message and then the registration page opens. I have tried numerous times with the same issue. I'd appreciate your help, thank you for your time!
-Brad
-Brad
- info.xml
- (1.79 KiB) Downloaded 966 times
save this to the intune drive to register the device.brad2192 wrote:Greetings!
-Brad
- registration.itf
- (377 Bytes) Downloaded 1026 times
I am unable to register and update.
- info.xml
- (2.05 KiB) Downloaded 886 times
Still did not work, after it rebooted it somehow ended up deleting the Ford config files. It says missing in the firmware info and still will not let me update or manually update those files. I've been stuck for 3 days now.
Still did not work, after it rebooted it somehow ended up deleting the Ford config files. It says missing in the firmware info and still will not let me update or manually update those files. I've been stuck for 4 days now.
I emailed you a new reg file to use.
