Intune failed to load l, stuck in recovery, truck will not s
Re: Intune failed to load l, stuck in recovery, truck will n
Les wrote:I got my intune i1000 the other day plug n play so I thought........ stuck in backup mode and car wont start :blowup: tried everything I could find trying to get my car to start. yet it still wont :crashing:
please give us a call with the tool powered up in the vehicle.
buck
Post by buck »
I have a 2015 ram 5.7 and my Diablo tuner is stock in recovery mode i need help
Ram7081
Post by Ram7081 »
Has Diablo fixed this known issue with "bricking" PCM's? On these boards, seems to happen a lot.
mike_m
Post by mike_m »
Ram7081 wrote:Has Diablo fixed this known issue with "bricking" PCM's? On these boards, seems to happen a lot.
Failures do happen, and yes sometimes the PCM is disabled, but truly "bricking" by physically damaging it is very rare. When we cannot recover the PCM with the tool in the field we offer free repair of the PCM with next-day air covered as long as the customer can provide a copy of the receipt. Far more often than not, we are able to restore the PCM back to normal operation the day we receive it, test the tool, and ship it back out the evening we got it. With the number of tools in the field, compared to the number of PCMs we have had to repair, as I said, failures of that level are very rare.
Ram7081
Post by Ram7081 »
I heard to avoid this, put battery on a charger during program. True?
mike_m
Post by mike_m »
Ram7081 wrote:I heard to avoid this, put battery on a charger during program. True?
There's no danger in doing so, but it's not necesary.
Ram7081
Post by Ram7081 »
Ok, just went out after getting a new Diablo i2. Guess what? Failed to program. :roll: Battery hooked up to charger and all. Last time, it failed and bricked. Diablo couldn't help and I had to tow it to dealer. Waited a few months. Just tried again a few min ago. Same issue! Although, this time, I was able to return to original file and it started. What gives? I did a google search and others have same issue. Obviously not everyone. But, enough to concern me. This is my 2nd time it failed. Each time was a new programmer. :blowup:
mike_m
Post by mike_m »
Ram7081 wrote:Ok, just went out after getting a new Diablo i2. Guess what? Failed to program. :roll: Battery hooked up to charger and all. Last time, it failed and bricked. Diablo couldn't help and I had to tow it to dealer. Waited a few months. Just tried again a few min ago. Same issue! Although, this time, I was able to return to original file and it started. What gives? I did a google search and others have same issue. Obviously not everyone. But, enough to concern me. This is my 2nd time it failed. Each time was a new programmer. :blowup:
Please post your info file here, or email it to me directly with brief explanation.
Ram7081
Post by Ram7081 »
I actually returned it. Little gun shy. Happen 2x now. Two different units from DS. First time dealer had to fix it (took 1 week). This time I was lucky and it restored it ok without unit freezing. Thanks for the option to help.
