2015 Eco Boost Dead peddle Info Thread.
juangorena
Re: 2015 Eco Boost Dead peddle Info Thread.
can i load the Pkmaw3 file into my truck too ??
DiabloMatt
what do you mean?
juangorena
i´m lost, i was out of the country and at this moment i dont know what is the progress with Dead peddl or throttle issue , what can i do to have my programmer doing what is supposed to? do you have a fix ? i´m just asking
DiabloMatt
juangorena wrote:i´m lost, i was out of the country and at this moment i dont know what is the progress with Dead peddl or throttle issue , what can i do to have my programmer doing what is supposed to? do you have a fix ? i´m just asking
oh ok. i have 3 testers out. if they report back all is good, i will get the fix implemented. then all you have to do i update the tool and load in which ever tune you want.
juangorena
Ok Thank you,
DiabloMatt wrote:juangorena wrote:i´m lost, i was out of the country and at this moment i dont know what is the progress with Dead peddl or throttle issue , what can i do to have my programmer doing what is supposed to? do you have a fix ? i´m just asking
Here is my backup I can trial the tune.
- PCM_PKCMAK5_Backup.frg
- (165.67 KiB) Downloaded 221 times
DiabloMatt
adamtrop wrote:Here is my backup I can trial the tune.
here you go
- test 87 adam.frg
- (145.68 KiB) Downloaded 227 times
DiabloMatt
guys that have tester... could you keep track of things like number of times driven. roughtly how far. things like that. and report back here with reagular updates please. need to keep tabs on what is going on.
Installed the tune and had a throttle!!!!(previous tunes would result in no throttle immediately) I did some testing, 5 Keystarts and all were successful,
1. Normal Start: Foot on break and pull off forward drove around 5 minutes , perfect
2. Reverse Start: Foot on break, reversed (50ft) pulled forward off drove around 5 minutes, perfect.
3. Sport Mode: No Problem
4. Tow/Haul: No problem
5. Normal Driving: Prefect more power and the turbo boost gauge is more active than ever. Shifts seem responsive, the RPM hold high but not too aggressive.
Hopefully resolved!!! I will keep you up dated.
Good work guys.
Good work guys.
- (165.67 KiB) Downloaded 227 times
DiabloMatt
adamtrop wrote:Installed the tune and had a throttle!!!!(previous tunes would result in no throttle immediately) I did some testing, 5 Keystarts and all were successful,
Good work guys.
looking promising
DiabloMatt
where is me 2.7 guy at? Apostolic37?
post up your orginal backup.
and where dude garden at?
you too.
you too.
DiabloMatt
ozzcrash. can you give this a try. its the last tune written (modified) you posted a few pages ago.
- 2.7 test ozz.frg
- (153.36 KiB) Downloaded 229 times
kicker300zx
3.5 eco boost
- PCM_PKCMAC6_Backup.frg
- (165.67 KiB) Downloaded 245 times
Thank you!!DiabloMatt wrote:vig wrote:is this dead pedal problem just for the F150 or does it include all 2015 ecoboost like the explorer sport? thanks
we have only seen this issue on 15 f150s
Guys, i have a 87 tune ready to try. if you guys want to try it, please read the original backup out of your truck and post it up on here. NOT the info.xml file but the actual "orginial backup" and i'll make some.
DiabloMatt
kicker300zx wrote:3.5 eco boost
87 tune.... shaken not stired
- test 87 kicker.frg
- (145.67 KiB) Downloaded 230 times
