2015 Eco Boost Dead peddle Info Thread.
juangorena
Re: 2015 Eco Boost Dead peddle Info Thread.
Post by juangorena »
can i load the Pkmaw3 file into my truck too ??
DiabloMatt
Post by DiabloMatt »
what do you mean?
juangorena
i´m lost, i was out of the country and at this moment i dont know what is the progress with Dead peddl or throttle issue , what can i do to have my programmer doing what is supposed to? do you have a fix ? i´m just asking
DiabloMatt
juangorena wrote:i´m lost, i was out of the country and at this moment i dont know what is the progress with Dead peddl or throttle issue , what can i do to have my programmer doing what is supposed to? do you have a fix ? i´m just asking
oh ok. i have 3 testers out. if they report back all is good, i will get the fix implemented. then all you have to do i update the tool and load in which ever tune you want.
juangorena
Ok Thank you,
adamtrop
Post by adamtrop »
Here is my backup I can trial the tune.
PCM_PKCMAK5_Backup.frg
(165.67 KiB) Downloaded 223 times
DiabloMatt
adamtrop wrote:Here is my backup I can trial the tune.
here you go
test 87 adam.frg
(145.68 KiB) Downloaded 229 times
DiabloMatt
guys that have tester... could you keep track of things like number of times driven. roughtly how far. things like that. and report back here with reagular updates please. need to keep tabs on what is going on.
adamtrop
Post by adamtrop »
Installed the tune and had a throttle!!!!(previous tunes would result in no throttle immediately) I did some testing, 5 Keystarts and all were successful,
1. Normal Start: Foot on break and pull off forward drove around 5 minutes , perfect
2. Reverse Start: Foot on break, reversed (50ft) pulled forward off drove around 5 minutes, perfect.
3. Sport Mode: No Problem
4. Tow/Haul: No problem
5. Normal Driving: Prefect more power and the turbo boost gauge is more active than ever. Shifts seem responsive, the RPM hold high but not too aggressive.
Hopefully resolved!!! I will keep you up dated.
Good work guys.
(165.67 KiB) Downloaded 229 times
DiabloMatt
adamtrop wrote:Installed the tune and had a throttle!!!!(previous tunes would result in no throttle immediately) I did some testing, 5 Keystarts and all were successful,
Good work guys.
looking promising :mrgreen:
DiabloMatt
where is me 2.7 guy at? Apostolic37?
post up your orginal backup.
and where dude garden at? 8)
you too.
DiabloMatt
ozzcrash. can you give this a try. its the last tune written (modified) you posted a few pages ago.
2.7 test ozz.frg
(153.36 KiB) Downloaded 231 times
kicker300zx
Post by kicker300zx »
3.5 eco boost
PCM_PKCMAC6_Backup.frg
(165.67 KiB) Downloaded 247 times
vig
Post by vig »
DiabloMatt wrote:
vig wrote:is this dead pedal problem just for the F150 or does it include all 2015 ecoboost like the explorer sport? thanks
we have only seen this issue on 15 f150s
Guys, i have a 87 tune ready to try. if you guys want to try it, please read the original backup out of your truck and post it up on here. NOT the info.xml file but the actual "orginial backup" and i'll make some.
Thank you!! :D
DiabloMatt
kicker300zx wrote:3.5 eco boost
87 tune.... shaken not stired
test 87 kicker.frg
(145.67 KiB) Downloaded 232 times
Return to “General Support”
