Coolant fans
Coolant fans
What happened to being able to control the low fan mid fan and high fan? I need this feature back instead of just a desired ECT. How do i get it back? If it's not possible how can I fix the P0128 or something like that, whatever the coolant temp error code is. Any help is greatly appreciated!
Re: Coolant fans
2012 charger 3.6. 8 speed and awd if that mattersDiabloMatt wrote:what vehicle?
Re: Coolant fans
its not something you can get back, unless you can convince Chrysler to make the fans work that way againDmanw wrote:What happened to being able to control the low fan mid fan and high fan? I need this feature back instead of just a desired ECT. How do i get it back? If it's not possible how can I fix the P0128 or something like that, whatever the coolant temp error code is. Any help is greatly appreciated!
The code is generally caused by a cooler t-stat, post the current last tune written file.
Re: Coolant fans
I have a 180 t stat i think i failed to mention that. either way below 50 it stays around 172 degrees on the highway no matter what fan temp i use. around town its more responsive to fan temp changes.mikel wrote:its not something you can get back, unless you can convince Chrysler to make the fans work that way againDmanw wrote:What happened to being able to control the low fan mid fan and high fan? I need this feature back instead of just a desired ECT. How do i get it back? If it's not possible how can I fix the P0128 or something like that, whatever the coolant temp error code is. Any help is greatly appreciated!
I also have a custom tune if that mixes things up.
Re: Coolant fans
Bump. This is becoming a problem as my oil temp doesn't even get above 165 on the highway which keeps oil pressure around 72 psi when it should be around 40.
Re: Coolant fans
fix attached, this issue will not affect oil temp....
Re: Coolant fans
Thank you! I'll try it out this weekend. I'll have to try something else for oil temp.mikel wrote:fix attached, this issue will not affect oil temp....
Re: Coolant fans
Thanks for the fix its working great! No engine codes!mikel wrote:fix attached, this issue will not affect oil temp....
