PCM Calibration Update May Be Needed??
jhawker23
Post by jhawker23 »
I've updated my new inTune and when I plug it in to my '12 Durango 5.7 Hemi, it always stops at a message that there may be a calibration update and then instructions to connect to a PC. I do connect and after the updater runs, the inTune tells me I already have xxxxxxxxxxx loaded.
It's an endless loop!
Please help!
info.xml
(1.71 KiB) Downloaded 314 times
jhawker23
Re: PCM Calibration Update May Be Needed??
Post by jhawker23 »
After the 4th time, it worked.
96gtrlm
Post by 96gtrlm »
Same Problem here, tried 10 times on my 2014 Dodge Durango R/T 5.7L
HELP!
info.xml
(1.99 KiB) Downloaded 274 times
96gtrlm
Post by 96gtrlm »
sent an email, no response... How do you get help around here?
96gtrlm wrote:Same Problem here, tried 10 times on my 2014 Dodge Durango R/T 5.7L
HELP!
this tool is already married, was the vehicle at the dealer since the tune was loaded?
96gtrlm
Post by 96gtrlm »
Yes, but I don't believe they did anything to the pcm. I know they did a recall for hacking issues. Am I supposed to do something different when it goes to the dealer?
you should always restore when going to the dealer, as they will often flash thepcm.
Fax or email proof of the dealer service to us then call with the tool powered up and we will reset it .
