Hello,
Keep receiving the same error message now every time I plug in the intune to the laptop. Worked fine for the first month and then just?????
Please see the attached picture for the exact error message.
Here is the .xml file
<?xml version="1.0"?>
-<tool_info>
<main svn="8521" sw_rev="1r04i" full_version="InTune-1r04i 08/03/2015 01:32:36 PM"/>
<registration status="1" sn="KUFI0F0-8"/>
<cal_id CM2="23482558, 95406746, 22888290" CM1="24268165, 24274515, 24274513, 24274516" PCM="12656286, 92282771, 92282768, 12643594, 92275084, 92280931, 92280941, 92280936"/>
<restore bc="0" vin="1G1PG5SB5F7229871" id="0"/>
<system_db vin="1r01e" dtc="1r01a" info="1r01b"/>
<db pid="1r01b" tune="1r01f" mfr="DCX"/>
<db pid="1r01b" tune="1r02d" mfr="FORD"/>
<db pid="1r01a" tune="1r02q" mfr="GM"/>
<license tuned="0" avail="1"/>
<unsupported vin="1G1PG5SB5F7229871" oem="GM" calid="12656286, 92282771, 92282768, 12643594, 92275084, 92280931, 92280941, 92280936"/>
<updates count="9"/>
<oem tool_oem="DIABLO"/>
<reg reg="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"/>
</tool_info>
Intune computer Calibration ID Error
- diablo.JPG (1.3 MiB) Viewed 4430 times
Re: Intune computer Calibration ID Error
any files in the tunes folder?
post them here please.
here are the files in the tunes folder.
- ECM_92282768_LastTuneWritten.grg
- (115.06 KiB) Downloaded 320 times
- ECM_92282768_BackupDiabloTune.grg
- (114.01 KiB) Downloaded 309 times
- ECM_92282768_Backup.grg
- (114.63 KiB) Downloaded 296 times
save this to the intune drive and let the tool import it then go to the vehicle and click tune vehicle/write vehicle and let it load the update to set the pcm back to stock.shmigelz wrote:here are the files in the tunes folder.
- CTRL_92282768_UPDATE_1G1PG5SB5F7229871.grg
- (104.62 KiB) Downloaded 308 times
Thank-you. I'll try that and let you know if any issues.
