I2 Problems Car Dead on Dyno
lsxkilr
Post by lsxkilr »
Ok so a couple problems I am having with a brand new I2. So I have a car stuck on the Dyno... :blowup:
Problem 1-
I can not get the I2 to connect to my laptop that has my CMR software. Attached are the pics of my computer screen. I tried downloading the drivers and that did not help any.
So after failing to get Problem 1 resolved, I hooked up the I2 to a different computer (which connected to it). I was planning on emailing myself the files back & forth from the CMR Laptop to the Computer that Could connect to the I2.
Problem 2-
I ran the "Device Updater" because the 2012 Challenger I hooked it to, said it was not supported. I then went back to try again on the Challenger, it said it needed to download a "calibration update". -It failed on that and reboots to a "Recovery Mode". When I get it to go into Calibration Update again, it just stays on that screen FOREVER and never does anything. The car now does NOT start or do anything.
So these are the two problems I am having. Someone Please help.
Re: I2 Problems Car Dead on Dyno
they've been closed since thursday for the holiday man.. they'll be back in the office on Monday..
lsxkilr
Post by lsxkilr »
Ya, i figured I wouldn't get a response till Monday.
try disconnecting the batt cables and touch them together to drain voltage then reconnect and let tool try recovering again please.
lsxkilr
Post by lsxkilr »
Ok, I did the battery thing. Now I keep getting these screens when it goes into recovery mode:
please post all files from the i2 drive here including tunes, runtimes, and the info.xml file.
lsxkilr
Post by lsxkilr »
Ok, dont forget problem one:
Problem 1-
So I have to take it from one computer and load it on this one.
lsxkilr
Post by lsxkilr »
more
It wont upload "runtime_16.dbg" Says that it is EMPTY
lsxkilr
Post by lsxkilr »
more.
There are "No Files" in the "Tunes" folder.
OK, hold tight for 10 minutes as we confirm something.
OK, please plug the tool into a pc, and delete all the runtime files.
then, click NO on the screen and let the tool sit on the main menu, then load the attached file to the i2 drive and let the tool import it.
once its done, plug it bacvk into the car and let it recover and it should work.
Let me know, then we'll sort out your cmr, but if the drives are there, its all working ;)
lsxkilr
Post by lsxkilr »
Ok, I did all of that. Now its doing this whole crazyness:
https://youtu.be/6qwEPSTU7sw
UPDATE: Disregard the above vid, it started to go
Cool, let me know if it completes.
In CMR, just browse to the folder where the tunes are on the i2 drive and you can open them from there.
Save your custom tune to the PC, then put a copy of it in the root of the i2 drive and the tool will import the custom tune.
all good?
Return to “Ignition updater”
