2015 Eco Boost Dead peddle Info Thread.
2015bluef150
Re: 2015 Eco Boost Dead peddle Info Thread.
Post by 2015bluef150 »
DiabloMatt wrote:
2015bluef150 wrote:attached
drop this on your intune drive please. that should allow you to update it.
still says must be registered
DiabloMatt
Post by DiabloMatt »
wtf... hold on one sec
garrett
Site Admin
Post by garrett »
Did the file disappear from the drive? if so, the tool should now be registered. Please post the info file for me one last time, a fresh copy please. I'll double check that the registration was done successfully. Be sure the update isnt in the drive while you're trying to update the registration.
2015bluef150
garrett wrote:Did the file disappear from the drive? if so, the tool should now be registered. Please post the info file for me one last time, a fresh copy please. I'll double check that the registration was done successfully. Be sure the update isnt in the drive while you're trying to update the registration.
Yes - the file disappeared. fresh copy of info file attached.
info.xml
(1.71 KiB) Downloaded 354 times
hxrly
Post by hxrly »
I'll try out the updated file tonight. Please disable the start/stop for us 2.7l owners.
hxrly
Post by hxrly »
No dead pedal on the last update; however, there is a wrench and limp mode if revved all the way to redline. The wrench goes away after a restart and will not turn on if you only rev up to about 5k, but if you rev it up to 6k it will come back on.
So far no check engine light or fault codes, but the previous revision did give me an overboost fault (91 oct) after the wrench, so I'm assuming this one is the same issue.
LAFNGAS
Post by LAFNGAS »
instant dead pedal with the updated crom file installed........
here are the original backup and diablosport 87 tow tune
PCM_PKCMAK4.frg
(193.41 KiB) Downloaded 354 times
PCM_PKCMAK4_DiabloSport_Towing.frg
(9.25 KiB) Downloaded 352 times
kicker300zx
Post by kicker300zx »
Updated the I2 with the supplied update. Updated using the can 87 Tune and got instant dead pedal.
PCM_68192895AH_Backup.drg
(121.55 KiB) Downloaded 300 times
PCM_68192895AH_LastTuneWritten.drg
(121.55 KiB) Downloaded 305 times
sqeegee
Post by sqeegee »
sqeegee wrote:
DiabloMatt wrote:ok thank you very much.
you have been a huge help :)
were you able to put the custom tune back in it and have it work ok?
Put 91 test tune back in, plasma core at normal, all is good
Since loading 91 canned "ee" tune on friday ,working great 4 heat cycles, 15 key cycles, 400 miles
this is the first canned tune that went for more than 10 miles
amazing low end torque and keeps pulling strong
DiabloMatt
good deal!!!!!
kicker300zx wrote:Updated the I2 with the supplied update. Updated using the can 87 Tune and got instant dead pedal.
could you post your info.xml file please
LAFNGAS wrote:instant dead pedal with the updated crom file installed........
PCM_PKCMAK4.frg
options/show information, what is the version?
post your info file please.
kicker300zx
info.xml
(1.93 KiB) Downloaded 303 times
the tune filkes you posted earleir were from a Dodge, can you load the tunes to the F150 and post the files from that truck please?
kicker300zx
I tuned my jeep months ago. i have tuned my f150 probably 10 times since then. plus i took the tune off my jeep when i was helping with the f150 problem. i have no idea why its showing the jeep files. it was the only files showing. that is weird.
I will tune my truck on my lunch and report the files.
Return to “General Support”
