Not able to Update, Register and to load crom
Post by [email protected] »
I bought i2 for My Jeep wrangler 2013 3.6, and i have followed all instruction but no luck to update. i am trying for a week but no luck.
when i connect the tool with my PC it says : A Trinity Was found on COM12, and then when i update it says " DS Downloader is configured for Trinity, but the detected tool dose not appear to support the XML RPC protocol.
I have tried windows XP, 7, 8 and windows 10, and tried different USB ports, Uninstalled then reinstalled the DS and the drivers, but no luck.
DS tool info :
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM12 at 57600 baud.
XML RPC commands are NOT available.
Server:
and not able to register as well it always say invalid serial number.
Please HELP :lamer: :lamer:
Re: Not able to Update, Register and to load crom
what instructions are you looking at?
i2 does not use dsdl, the updater lives on the i2 drive on your pc in the updater folder :)
mikel wrote:what instructions are you looking at?
Thank you Mikel, I am not getting the i2 drive on m PC, i have installed the USB drivers .
sstevetx
Post by sstevetx »
Windows 10 didn't assign a drive letter to my new i2 initially, although it did automatically install the drivers. I suggest you uninstall any drivers you installed for it since newer versions of Windows should have the drivers already. After that, you may want to manually assign a driver letter like I ended up doing. Here's some instructions I found that will help you assign a drive letter. Instructions are for XP, but it's the same procedure in newer Windows versions.
http://www.online-tech-tips.com/compute ... ard-drive/
