2015 Eco Boost Dead peddle Info Thread.
tonumartin
Re: 2015 Eco Boost Dead peddle Info Thread.
Post by tonumartin »
Hello,
I got here a F-150 also with dead pedal.
Need 93 octane tune.
PCM_PKCMAW6_LastTuneWritten.frg
(165.34 KiB) Downloaded 315 times
PCM_PKCMAW6_Backup.frg
(165.68 KiB) Downloaded 340 times
info.xml
(1.73 KiB) Downloaded 306 times
DiabloMatt
Post by DiabloMatt »
tonumartin wrote:Hello,
if you go to the very first post and update your tool with the correct file for the tool you have. that should take care of it. :)
kicker300zx
Post by kicker300zx »
I tuned the truck at lunch yesterday. It accepted the tune this time and is still working. I didn't change anything on this tune compared to the prev tune. I have no idea why it worked this time and not Sunday.
I can still post the info file if you would like. i left my surface at home so it will be later.
but the good news is its working and i have missed it so much.
DiabloMatt
kicker300zx wrote:I tuned the truck at lunch yesterday. It accepted the tune this time and is still working. I didn't change anything on this tune compared to the prev tune. I have no idea why it worked this time and not Sunday.
we fixed a few more things.
we are actaully "releasing" the fix today. so soon you will just be able to update your tools the regular way and not have to use the tester updates.
2015bluef150
Post by 2015bluef150 »
2015bluef150 wrote:
garrett wrote:Did the file disappear from the drive? if so, the tool should now be registered. Please post the info file for me one last time, a fresh copy please. I'll double check that the registration was done successfully. Be sure the update isnt in the drive while you're trying to update the registration.
Yes - the file disappeared. fresh copy of info file attached.
Any update on this? I still can't update intune
hxrly
Post by hxrly »
Matt, are you going to disable the start/stop for the 2.7 on the release? If not, can you modify my tune to get it disabled?
DiabloMatt
hxrly wrote:Matt, are you going to disable the start/stop for the 2.7 on the release? If not, can you modify my tune to get it disabled?
as far as i know the start stop will be included in the release.
i'll get garrett to look into this more
garden98
Post by garden98 »
Matt, just wanted to let you know that the custom 87 octane tune you did for me now has 1000 miles on it and is still doing fine. My 2015 F150 Lariat 4x4 3.5 ecoboost has never run better, and is getting a little better gas mileage in mixed driving than stock. Just have one question I need to ask since you are releasing an update to the canned tunes. Would there be any advantage to me to update and load the can 87 octane tune? I don't know what the difference is in the custom tune you provided me, that is working fine, and the canned 87 octane tune being released (with the fix for the dead pedal incorporated). Since you seem to be the expert, I figured it couldn't hurt to ask.
DiabloMatt
garden98 wrote:Matt, just wanted to let you know that the custom 87 octane tune you did for me now has 1000 miles on it and is still doing fine. My 2015 F150 Lariat 4x4 3.5 ecoboost has never run better, and is getting a little better gas mileage in mixed driving than stock. Just have one question I need to ask since you are releasing an update to the canned tunes. Would there be any advantage to me to update and load the can 87 octane tune? I don't know what the difference is in the custom tune you provided me, that is working fine, and the canned 87 octane tune being released (with the fix for the dead pedal incorporated). Since you seem to be the expert, I figured it couldn't hurt to ask.
they are the exact same tunes now... so TECHNICALLY there is no difference. its up to you. obviously updating the tool and using the canned tunes will allow you to switch around to different tunes as opposed to running just the custom. but other than that no difference.
joic0205
Post by joic0205 »
can i update my tune now ? is the problem fixed?
Roiceed
Post by Roiceed »
joic0205 wrote:can i update my tune now ? is the problem fixed?
wondering the same thing.
yes, updates are out and issue is resolved.
spex911
Post by spex911 »
It's been a long time waiting for this! I just want to say all of you are awesome. You all had a tough time trying to figure this out and you all did it. Thank you guys for all your hard work on this. You all rock... Team Diablo Sports at its greatest!
Roiceed
Post by Roiceed »
So does the race feature work now as well?
2015bluef150
It still will not update. Continues to go to registration website
Return to “General Support”
