what is canned 87 octane throttle setting?
Hey guys. does anyone know, on the 2014 silverado 5.3L what the canned 87 octane, firm shift is set at? i changed it to 10% but wanna try it back to what Diablo had it at in the canned setting. I thought it was 15%, but wasnt certain.
Re: what is canned 87 octane throttle setting?
like I mentioned in our messages last night, just select the tune, Modify the tune, select RESET ALL PARAMETERS and then install the tune.. that will put it back at the default diablosport settings..
Ya, i did what you said thx. I posted this before i sent you the mssg. I appreciate the help.
aaah, ok.. haha, cool
does the 87 octane tune remove overdrive?
no..
OK. i didnt figure. im not used to it holding the gears for longer periods.
the preset tunes do not change shift points either.. only shift pressure is changed and how quick it shifts.. shift points (mph/rpm) are still stock.
