HMMMM HELP ???
HMMMM HELP ???
I have a 06 5.7 here is my issue .Everytime I try to turn off MDS,rear o2,and change the axle ratio to 3.06 the car doesnt like it at all(acts like it has a stall conv. and wont turn over 60 mph at a high rpm ). Now I can just do MDS and it drives fine,without changing any of the other 2 parameters. Anyone else have that problem?????
RE: HMMMM HELP ???
Its the axle ratio parameter causing this.
You should not be changing that unless you have actually changed the gears. Put this back to stock.
RE: HMMMM HELP ???
OK thanks Mike !!! You guys have great customer support,and a great product
FRI STREET HEADS<SIDEWINDER CAM<SLP LT>BORLA125's>180deg.STAT<RAMAIR
