Gents,
I wanted to use stock tune and modify Fan Temps (turn on at 190), eliminate CAGS and Throttle Boost to 20%. When I went to modify tune followed the instructions after answering the questions I got a * by CAGS and Throttle Boost none by Fan Temps. Driving the car when the parameters are met the 1-4 shift lite comes on and the CAGS shifts to 4th gear. In addition I do not hear the fans coming on at 190 degrees. Any suggestions?
PS If I add your 91 Octane tune is the increase HP and TQ at the rear wheels or flywheel. Thanks in Advance!
v/r
Steve
FAN TEMPS AND CAGS
Re: FAN TEMPS AND CAGS
what's the vehicle year, model, engine??
throttle boost is only on 2014, 2015 trucks & vettes..
and on those vehicles, you can not change fan temps.. only the percentage of power that the fans run at, at given temps.. you can't change the temps.
Sorry MonteSS,
2015 Z06...Copy on fan Temp. The program will not let me choose % of increase on the fans.
The Yav
The Yav
