vehicle not currenlly supported.Plug in to update
vincetinker
Post by vincetinker »
Did this several times and I get same results. I2 doesn't show any tunes. Also windows says "there is a problem with the drive"
scans drive and reports no problem with drive.
Re: vehicle not currenlly supported.Plug in to update
what vehicle?
please post the info.xml file from the i2 drive.
drlargin
Post by drlargin »
I have had this problem as well with my 07 mustang GT.
keepsicx
Post by keepsicx »
i have the same problem wont update also only opens a file that has 4 different files with nothing in them i havent put it on my ford ranger yet because it says to do an update first dont want to mess the truck up or anything am i able to try to put it in without the update to see if it has the tunes in it? also getting a problem with the drive too, but saus its fixed works a couple times wont say error but sometimes it will say error, also all the memory is available on it
uplander
Post by uplander »
Having same problem updated the i2 and when plugged into jeep it says that it is not supported ????????????????? Not a happy camper!
XML file below:
info.xml
<tool_info>
<registration sn='14U7Z5KKG7' status='0' tool_oem='DIABLO_F' updates='0'/>
<applications count='5'>
<application name='vehicle' rev='2r01d'/>
<application name='updater' rev='missing'/>
<application name='gui' rev='2r01b'/>
<application name='installer' rev='2r01a'/>
<application name='logger' rev='2r01a'/>
</applications>
<databases dbnames='2r00' dtc='2r01a' vin='2r01fa' gui='2r01b'>
<database mfr='DCX' pid='2r01cc'/>
<database mfr='FORD' tune='2r02e' pid='2r01cf'/>
<database mfr='GM' pid='2r01ba'/>
</databases>
<last-connected vin='1J4FA241X8L556844' mfr='DCX' calid='05187470AG'/>
<licenses available='1' tuned='0'/>
<reg reg='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'/>
</tool_info>
uplander
Post by uplander »
Ok I ordered this from extreme terrain and was drop shipped directly from diablo sport , looking at the box it says this is for a FORD its a i2020 not the i2010 that was ordered. Is this as simple as adding the correct file or does this need to be returned ?????????????????????????
uplander wrote:Having same problem updated the i2 and when plugged into jeep it says that it is not supported ????????????????? Not a happy camper!
XML file below:
info.xml
<tool_info>
</applications>
</databases>
</tool_info>
HemiGod
Post by HemiGod »
I have a 2014 Dodge Challenger R/T every time I plug it in to my car says that it is not supported seek updated, I did a automatic updated and says it's up to date but still does not work.
<?xml version="1.0"?>
-<tool_info>
<registration updates="0" tool_oem="DIABLO_D" status="0" sn="14U7Z5M56H"/>
-<applications count="5">
<application rev="2r01d" name="vehicle"/>
<application rev="missing" name="updater"/>
<application rev="2r01b" name="gui"/>
<application rev="2r01a" name="installer"/>
<application rev="2r01a" name="logger"/>
</applications>
-<databases gui="2r01b" vin="2r01fa" dtc="2r01a" dbnames="2r00">
<database pid="2r01cc" tune="2r01b" mfr="DCX"/>
<database pid="2r01cf" mfr="FORD"/>
<database pid="2r01ba" mfr="GM"/>
</databases>
<last-connected vin="2C3CDYBT4EH224919" mfr="DCX" calid="68212718AE"/>
<last-connected calid="05150891ACke3z0"/>
<licenses tuned="0" available="1"/>
<unsupported vin="2C3CDYBT4EH224919" calid="68212718AE" oem="DCX"/>
<reg reg="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"/>
</tool_info>
HemiGod wrote:I have a 2014 Dodge Challenger R/T every time I plug it in to my car says that it is not supported seek updated, I did a automatic updated and says it's up to date but still does not work.
-<tool_info>
</applications>
</databases>
</tool_info>
Please attach the info.xml file to the post here.
Return to “Ignition updater”
