Speed limiter
Speed limiter
I just installed the t-1000 today on my 2014 ram 1500. I installed the 91 performance tune. All I see that I can adjust is tire cal and traction control on/off. There is no other options. I thought I could remove the limiter with this??
Re: Speed limiter
YOU NEED TO MODIFY YOU TUNE BEFORE YOU INSTALL IT, ITS NOT IN THE QUICK ADJUST.
Re: Speed limiter
I can only modify my stock tune. I want to run the performance 91 tune with the speed limiter off. Is there a way to mod that tune? Another question is when I change a tune do I have to remove the other one first? Or just pick the new one and install it? When I changed my performance 91 tune to modify stock tune i just installed it without removing the 91 tune.
Re: Speed limiter
Anyone? Did I spend $800 to just change the speed limiter?
Re: Speed limiter
there are a ton of adjustments available in the modify tune menu, you seem to be looking only in the quick adjust menu.
Re: Speed limiter
I see the loads of adjustments I can make to the stock tune, but it won't let me modify the 91 performance tune. I'm not into the quick adjust sceen.
Re: Speed limiter
After re-selecting my vehicle again, it now will let me mod the Diablo tunes.
