2016 Explorer Sport
DrPepper100
2016 Explorer Sport
I have a 2016 explorer sport and would like to modify it. I previously tuned my 2014 explorer sport and it was great. Is there a projected time of availability for the 2016 tune? Could I use the tune from 2015 edition explorer sport? Thanks.
Re: 2016 Explorer Sport
Do you have a trinity currently? If so plug into vehicle and go to options - troubleshooting - show calibration ID
Tell me what it displays.
Insert Clever comment here...
DrPepper100
Yes I have a Trinity- under calibration it says KJDW2G4.
It lets me install some sort of "modify stock tune" but there are not options for horsepower, fuel economy etc. And to be honest, I couldn't tell a difference when I did install the "stock tune" so I took it off.
Well that's all that tune is. Just stock image if you wanted to only adjust parameters with the tool.
If you post your original backup from the tool I will make something for you to try.
DrPepper100
To sohfast94. Here is the back from my 2016 explorer sport. I would really appreciate a tune for max horsepower/speed (what else?
- PCM_KJDW2G4.frg
- Last Backup
- (145.19 KiB) Downloaded 779 times
Here you go. Make sure when you load this and it asks for a second file that you select the file you originally read out being the original backup otherwise it won't load anything to the tool.
- PCM_KJDW2G4_93.frg
- (109.67 KiB) Downloaded 918 times
DrPepper100
Sohfast94. Thanks for working on this. I tried installing it twice and each time I installed it, the car wouldn't start so I had to re-install the factory settings.
It does say that I am installing a Ford Predator tune. Not sure if there is a fix?
Again, I appreciate all your help.
Brian is on vacation this week but we will sort this out for you next week for sure.
DrPepper100
Just wondering if you have had any luck with the custom tune?
kolezimmer
I am also curious about progress. Today I updated my Intune I1000 and decided to plug it into my 2016 Explorer Sport. I was pleased to see the new availability of MPG, 87, 91 and 93 octane tunes. I tried the 87 Octane tune, and the vehicle failed to start, just cranked away. So close. Back to stock and patiently waiting for another update.
Yeah, we havent announced the availability of these tunes just yet as we're working through some testing.kolezimmer wrote:I am also curious about progress. Today I updated my Intune I1000 and decided to plug it into my 2016 Explorer Sport. I was pleased to see the new availability of MPG, 87, 91 and 93 octane tunes. I tried the 87 Octane tune, and the vehicle failed to start, just cranked away. So close. Back to stock and patiently waiting for another update.
DrPepper100 wrote:Sohfast94. Thanks for working on this. I tried installing it twice and each time I installed it, the car wouldn't start so I had to re-install the factory settings.
Does it give you any codes with the tune installed?
DrPepper100
I don't have it installed anymore so I can't check. However when it was there I didn't see any code and it said it was installed successfully.
Need you to install it and then check the dtcs. Also this time install the modify stock tune so I can eliminate the checksums.
How do I get my inTune 1000 to download the performance tunes for my 2016 explorer sport? It just has stock mods available. I had this tuned and associated with my 2013 f150 ecoboost but want to tune my explorer instead.
