i2 stuck on screen
DSPTUNEDSRT
Re: i2 stuck on screen
Post by DSPTUNEDSRT »
mikel wrote:delete all that stuff, thats being put there by your Mac it seems
should only have logs/tunes/runtimes/updater folders, and info.xml file.
done. Deleted everything but the trashes file. Wont let me do it. and it seems like some of the files come back after deleting them. But I emptied the trash folder and now have 103.3 mb free.
What's next?
DSPTUNEDSRT
nows there's more memory free than there is available... :facepalm:
got access to a PC?
DSPTUNEDSRT
mikel wrote:got access to a PC?
I don't. and I can't do it at work.
DSPTUNEDSRT
I really appreciate the help but I started this thread 5 days. is there a way I can talk to someone with full attention and get this handled?
everyone told me I was an idiot for not going with sct to tune a mustang, especially since there's tuners in my city. but I've been a loyal Diablo sport supporter for 6 years. if I have to have a PC to fix all this I'd rather just go to a shop with the sct and get this all handled.
and by no means is this disrespect. still a supporter.
DSPTUNEDSRT
bump
try ejecting it and see if the drive repopulates with the correct size?
Please feel free to call in with the tool powered up at the mac and we can check it out.
DSPTUNEDSRT
mikel wrote:try ejecting it and see if the drive repopulates with the correct size?
okay I will. sorry I've had pneumonia. friggin nightmare.
I'll call as soon as I'm better.
DSPTUNEDSRT
Gave you guys a call, but not open on the weekends.
I'll call Monday. Any other tips I could try before then?
DSPTUNEDSRT
Okay, so I got my i2 back, but none of my tunes are on it, including my stock tune. Now what?
let it tune the vehicle and if needed it will prompt you to check for an update to reload a stock tune then the tool will read that out.
DSPTUNEDSRT
mikel wrote:let it tune the vehicle and if needed it will prompt you to check for an update to reload a stock tune then the tool will read that out.
okay, so I'm getting this message
DSPTUNEDSRT
if you could give me a call, that would be awesome.
connect to a pc and let the updater run and check for updates, then go to the car and load the update then you should be able to tune it.
DSPTUNEDSRT
mikel wrote:connect to a pc and let the updater run and check for updates, then go to the car and load the update then you should be able to tune it.
it says there's no updates available at this time.
Return to “Ignition updater”
